vernonlee
HELP: Lisp to hatch multiple closed polylines but result in individual hatch objects
vernonlee
Looking for a hatch lisp to window select multiple closed polylines & hatch them at once but result in individual hatch objects, base on current hatch settingd.
Came across this code but was it unable to base on current hatch settings
(defun c:mhatch (/ ang do-it doc hatch oname pname scl space ss)
(if (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(setq scl (getvar "hpscale")
ang (getvar "hpang")
pname (getvar "hpname")
hpassoc (if (= (getvar "hpassoc") 1)
:vlax-true
:vlax-false)
doc (vla-get-activedocument
(vlax-get-acad-object))
space (if (= (getvar "cvport") 1)
(vla-get-paperspace doc)
(vla-get-modelspace doc)
(vlax-for ent (vla-get-activeselectionset doc)
(setq do-it nil
oname (strcase (vla-get-objectname ent)))
(cond ((vl-string-search "CIRCLE" oname)
(setq do-it t)
((and (vl-string-search "LINE" oname)
(eq (vla-get-closed ent) :vlax-true)
(setq do-it t)
((equal (vlax-curve-getstartpoint ent)
(vlax-curve-getendpoint ent)
1e-6)
(setq do-it t)
(if do-it
(setq hatch (vlax-invoke space 'addhatch acHatchObject pname hpassoc))
(vlax-invoke hatch 'appendouterloop (list ent))
(vlax-put hatch 'patternangle ang)
(vlax-put hatch 'patternscale scl)
(vla-evaluate hatch)
Thanks
Share this post
Link to post
Tharwat
Hi,
I have just wrote this program and added to my Lisp-box :)
(defun c:Test  (/ h _doc ss)
;;;	Tharwat 20.01.2014	;;
 (princ "\n Select closed objects to hatch as per current hatch settings ")
 (if (setq _doc (vla-get-activedocument (vlax-get-acad-object))
           ss   (ssget '((-4 . "<OR")
                         (0 . "CIRCLE,ELLIPSE")
                         (-4 . "<AND")
                         (0 . "LWPOLYLINE")
                         (-4 . "&=")
                         (70 . 1)
                         (-4 . "AND>")
                         (-4 . "OR>"))))
   (vlax-for o  (vla-get-activeselectionset _doc)
     (setq h (vlax-invoke
               (vla-get-block (vla-get-activelayout _doc))
               'addhatch
               acHatchObject
               (getvar "hpname")
                 :vlax-true
                 :vlax-false)))
     (vlax-invoke h 'appendouterloop (list o))
     (vlax-put h 'patternangle (getvar "hpang"))
     (vlax-put h 'patternscale (getvar "hpscale"))
     (vla-evaluate h)
 )(vl-load-com)
Share this post
Link to post
vernonlee
Hi Tharwat.
Tested it & somehow it will not follow current setting which is non associative.
When using the LISP to hatch, it still hatch as associative.
Any advise on this?
Thanks
Edited by vernonlee
Share this post
Link to post
Tharwat
It seems that the parameter for the association is not making any sense with the use of the vlax-invoke function :o
Try this instead and let me know :)
(defun c:Test  (/ soc h _doc ss)
 (princ
                 :vlax-true
                 :vlax-false)
                         (-4 . "<AND")
                         (0 . "LWPOLYLINE")
                         (-4 . "&=")
                         (70 . 1)
                         (-4 . "AND>")
                         (-4 . "OR>"))))
               'addhatch
               acHatchObject
               (getvar "hpname")
               soc))
     (vla-put-AssociativeHatch h soc)
     (vlax-put h 'patternangle (getvar 'hpang))
     (vlax-put h 'patternscale (getvar 'hpscale))
     (vla-evaluate h)
 ) (vl-load-com)
Share this post
Link to post
vernonlee
Hi Tharwat.
I now works.
But i realised some of the polylines are not closed but look close (did not know there was such a thing), which the normal hatch command can select.
Could you include those that can be selected by normal hatch command? :oops:
Thanks
Edited by vernonlee
Share this post
Link to post
Tharwat
Why you are quoting every reply ? just a simple reply is more than enough if you don't reply to a specific point , remove the two programs from your replies please to keep the thread 's representation looking good at least .
Replace my selection set function with yours .
eg.
with the highlighted codes ONLY .
                 :vlax-true
                 :vlax-false)
[color="red"]            ss   (ssget '((-4 . "<OR")
                         (-4 . "<AND")
                         (0 . "LWPOLYLINE")
                         (-4 . "&=")
                         (70 . 1)
                         (-4 . "AND>")
                         (-4 . "OR>")))[/color]
Share this post
Link to post
vernonlee
Roger. Will clean up my previous post.
Did the code replacement & i got this error when i load the lisp
; error: malformed list on input
my code after replacement is this
 (princ
                 :vlax-true
                 :vlax-false)
               'addhatch
               acHatchObject
               (getvar "hpname")
               soc))
     (vla-evaluate h)
 ) (vl-load-com)
Share this post
Link to post
Tharwat
No , Read this modification and compare it with your last reply .
 (princ
                  :vlax-true
                  :vlax-false)
               'addhatch
               acHatchObject
               (getvar "hpname")
               soc))
     (vla-evaluate h)
 )(vl-load-com)
Share this post
Link to post
vernonlee
Ok. I guess as much I did something wrong. Will compare them to see where I went wrong when I am back in office tomorrow & test the code as well. Will feedback then.
Thanks again bro.
Share this post
Link to post
Tharwat
Good luck :thumbsup:
Share this post
Link to post
vernonlee
Hi Tharwat.
Tested it & had this error. Also not all selected objects are hatched. Out of 25 selected, only 6 are hatched.
Command: TEST
Select objects: Specify opposite corner: 25 found
Select objects:
Hatch boundary associativity removed.
Hatch boundary associativity removed.; error: AutoCAD.Application: Invalid input
Command:
Share this post
Link to post
Tharwat
That error took a place due to selecting open objects .
Share this post
Link to post
vernonlee
Tested it further & yes that is correct. If there is an open object within the selected, that error will occur.
Will play around with the 2 lisp to see which fits me better.
Thanks again :thumbsup:
Share this post
Link to post
Tharwat
And that's why I have changed the way of selecting objects before to avoid selecting open Polylines ;)
Share this post
Link to post
BlackBox
For those that may be interested... I just use this to select what I want to hatch, right click, and select Quick Hatch:
Cheers
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
