join command
PatDoc63
Hi everyone,
I often use the join comand selecting all objets and it works fine. But why when I try to input it in my lisp routine it crash.
I also try to write directly (command "join") in command line and it does'nt works.
Anybody can explain ?
Thank's
Ah ! Le français... ;-)
Edited by PatDoc63
Resolved
What doesn't work?
Is there an error message?
Does it seem to work, but the selected objects are not joined?
Are you selecting a "source object" first?
Well, when I use the command, all I have to do is selecting all objects without selecting a source object:
Command: join --> all --> enter
But in command line, I can't because autocad wait for me to select a source objet first, and I don't want to...
I wish i'm clear because english is not my native language.
In vertical versions (ie C3D), you may need to use .JOIN to use the core AutoCAD command.
Thank you nestly for your answer.
The command works directly in c3D.
It's when I put it between parenthesis there is a "nil" auto answer for "selecting source object first". That's what bugging me.
Yes I understand the difference. And if I write: (command ".join") or (command "join") I'm ask to select the source objet in both cases...
You'll have to call 'initcommandversion' first
(initcommandversion)
(command "_.join" "_All" "")
Henrique
