CADINATOR 10 Posted January 24, 2015 Hi, brand new to this site and my very first thread! I am trying to write a LISP routine and basically have no experience with it except for opening them up and trying to decode it for my self. I am going over lisp basics right now but thought I would through this out there in hopes of learning something from you fine folks. What I need to do is draw a series of circles and rectangles and label them from values in a .CSV file. As I mentioned I am going over the basics and am having trouble keeping my head above water, so be kind please. Thanks in advance, CADINATOR Quote Share this post Link to post Share on other sites
Lee Mac 260 Posted January 24, 2015 Welcome to CADTutor! What is the format of the data contained in your CSV file? Quote Share this post Link to post Share on other sites
BIGAL 220 Posted January 24, 2015 A simple alternative if you have CSV stay in excel and just write a defacto script works with LT also, the key is using concatenate(a1,".",b1) = "123,456" just copy the new column straight to the command line. 123,456,22 = CIRCLE 123,456 22 123,456,789,910 = Rectang 123,456 789,910 Like lee post csv so can show 2 ways to do same thing. Quote Share this post Link to post Share on other sites
CADINATOR 10 Posted January 27, 2015 (edited) Sorry for the long response time. I am not sure what you mean about just using an excel sheet. Attached is an example of tools with diameters and some with length and widths. Took me a while to figure out how to post the Excel file. Thanks for your help. TEST.xlsx Edited January 27, 2015 by CADINATOR Quote Share this post Link to post Share on other sites
BIGAL 220 Posted January 28, 2015 Have a look at this just copy column I to command line TEST2.xlsx note do vpoint 1,1,1 to see thickness. Quote Share this post Link to post Share on other sites
CADINATOR 10 Posted January 28, 2015 Wow! that works pretty slick. I am just not sure how you did that in excel. What do the values in column G and H represent? Quote Share this post Link to post Share on other sites
BIGAL 220 Posted January 29, 2015 H & G If I used a base of 0,0 all objects would be on 1 point so just put them 50 units apart, if you nominate shaft length it will appear in 3d as well. A little bug 2013 if you set thickness then rectang it has zero thicknes compared to a pline of 4 sides any ideas any one ? Hence use of chprop after using rectang. Quote Share this post Link to post Share on other sites
CADINATOR 10 Posted January 29, 2015 Oh, I see. that makes sense for the spacing. So this would work for what I need it for. I would love to use this if you don't mind. Am I able to say add new tools to this sheet when I have other kits that have tools by dimension? Or would I have to re write the language every time I have a different set of tools? If my list was longer would I be able to expand on it by copying the expressions to different rows keeping in mind adding spacing in column's G & H? Quote Share this post Link to post Share on other sites
BIGAL 220 Posted January 30, 2015 1 You are welcome to use. 2 make new tools 3 just copy formula 4 it could be smarter and check if circle or sq by cell is blank then use rectang or circle you can do IF's in excel Quote Share this post Link to post Share on other sites
CADINATOR 10 Posted February 6, 2015 Perfect!! Thank you very much. Quote Share this post Link to post Share on other sites
