insert a field using LISP
nod684
hi all, can someone help me make this process shorter...
what i do is like this:
- select an attributed block
- insert a field
- in the Field Names i select object then i choose another attributed block for the value or viewport for the custom scale i need
- in the Object Type Property I select value or custom scale
- in the format I select uppercase or 1: # (if i select custom scale) then click ok.
Edited by nod684
You could create a program using my Quick Field utility to perform this task.
hi lee, can you help me with the format for the value?
im trying to incorporate it in your QuickField lsp...
(see attached)
For the property & formatting code shown in your image, you would need to use:
(defun c:test ( ) (LM:QuickField "TextString" "%tc1" 1))
However, since the program doesn't allow you to select nested objects (such as attributes) by default, you will also need to change line 248 from:
(list 'if '(setq ent (LM:SelectIfHasProp prop entsel))
to:
(list 'if '(setq ent (LM:SelectIfHasProp prop [color=red]n[/color]entsel))
  • Thanks 1
to:
thanks Lee, will try this one out
EDIT :
was able to select the nested attribute to the target attribute but its displaying as ####
EDIT :
Does a regen cause it to display correctly?
  • Thanks 1
yes it did. Thank you.!
one more thing if its not too much to ask.
what format will i use if i want to insert the scale of the viewport thru field?
Edited by nod684
You're welcome!
I'm happy to guide you, but could you please post a clearer image of the Field dialog, as the image that you have attached is too pixelated to decipher the field code - ensure the image is saved as a vector format such as png/gif and is not larger than 800x600 otherwise the forum will automatically convert the image to a jpg and scale it down.
  • Thanks 1
You're welcome!
sorry about that...here is a bigger image
and heres the field expression
%<\AcObjProp Object(%<\_ObjId 8796086054176>%).CustomScale \f
"1:%lu2%ct1%qf2816">%
Thank you - in that case you could define a program with the following parameters:
(defun c:test ( ) (LM:QuickField "CustomScale" "1:%lu2%ct1%qf2816" 1))
Do you see the pattern and understand how the sections are taken from the field code?
  • Thanks 1
thanks a lot for the help Lee. I appreciate it a lot.
yes my mistake...i fo like this :
(defun c:test ( ) (LM:QuickField "Scale" "CustomScale" "1:%lu2%ct1%qf2816" 1))
again thank you! :)
and thanks too to pBe fo the vla-regen
cheers guys!
  • 9 months later...
Hi Lee,
How can I get dynamic block user parameter value with QuickField lisp. ?
%<\AcObjProp Object(%<\_ObjId 140694963280112>%).Parameter(96).UpdatedDistance \f "%lu2%pr0">%
Hi Lee,
This is unfortunately not possible using my Quick Field program.
  • 3 years later...
Hi everyone!
Could someone write a LISP for copying text contents from text 1 to text 2, and when the contents of text 1 change, then the contents of text 2 will automatically update contents from text 1! Thank you
You can use my existing Quick Field program for this task, defining a custom command such as:
(defun c:tcopy ( ) (LM:quickfield "Textstring" "" 1))
Edited by Lee Mac
  • Like 2
  • Thanks 1
  • 1 month later...
Yes! I've figured it out with your great Quick Field, but with little help of your other post:
Thank you! For one of types of my projects, that is great!
But today I faced with small complication.
Situation: I have dozens of projects with dozens of block in each (few types). These blocks has 3 or 4 attributes, but each attribute has few data types in it separated with comas. Blocks acts like annotation objects and at the end are exported to tables/excel sheets etc.
I need to place field with length value but only in very particular place of string in attribute. I know, that is achievable by formatting field, but it's to difficult with many block and types of data in it.
Best idea to manage my problem is to make similar lisp as your QuickField but instead of replacing attribute content it would copy field code into clipboard, so it would be pasted in right way while editing attribute.
Thanks again. Would you Lee and guys point me the way to place field code to clipboard?
  • 1 year later...
Hi Lee, can you please help me to implement next one in the quickfield:
My QuickField application is designed to generate fields which reference object properties, and so may only be used to generate field expressions found under the 'Object' category within the FIELD command dialog. As @tombu has helpfully suggested, field expressions with no dependence on Object IDs may be embedded directly within a template without losing the ability to update the field value.
  • Like 2
