"Mitch"
Page Setup Layout White Sheet Moves
"Mitch"
Hellllp!!!
I'm supposed to be able to do two different white sheet page setups in paper space and switch between each setups without having to move my drawing into the printable area. But the white sheet moves more than 3 feet between each setup!! Can I get the sheet to more or less stay in one place, so I can switch between each setup and print? One is for publishing to Acrobat and the other is to my network printer in the office.
Share this post
Link to post
mxpxh2o
If you are using a template to create your layouts you could just do a page setup on the layout template and change it to window and put it around your border. It wont fix drawings that are already done but will set up all new drawings to a standard.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
