astitchintimesaves9
Problem changing display colour of xref polylines..
astitchintimesaves9
I need to produce a pdf in black/white/red. To achieve this I'm using a colour ctb but changing all the viewport layer display colours to white (except the linework that I need in red) and therefore print black. The problem linework is xref and seems to be either circles, rectangle or 3D polylines, that will not change their viewport display colour even though I have actually changed them to white? They just print their original colour.
Edited by astitchintimesaves9
Share this post
Link to post
kbgooner
Is it not possible to just change the colours on the xref file?
Share this post
Link to post
RobDraw
Yes, the color(s) of the objects in the XREF need to be set to "ByLayer" in order for the XREF layer to control the color.
Share this post
Link to post
astitchintimesaves9
Not all linework set to 'ByLayer'.
Thanks,
Dain
Share this post
Link to post
Dipali
Open you ctb file and edit. Select white/ black for all colors other then red. And if the xref file is not using true color you will be able to print black and white.
Share this post
Link to post
