I am setting up two styles. One has a frame around the text and the other does not have a frame.
The problem is this: The style with the frame around the text is funky!!!! It looks as the the frame is to tight to the text. Is there a way to adjust the margin between the text and the fame.
My other option was to create a style that uses a block that i predefine. and that is a whole nother headache!!!
Any help is greatly appreciated!!
I don't think so. I thought that the dimgap variable would control it - but it doesn't. :o The best I can offer is to go back to the qleader command and use dimgap to control the distance between the text and the frame. Not what you asked but it's a suggestion anyway. Can anyone else help?
