Miller87
How selecting all points with minimum Z coordinates
Miller87
Hy,
that's the question:
I have several points in my drawing, all I want to do is select the points with the lowest Z coordinate (MIN) and insert a block in that specific points.
Is there any special filter selection using SSGET?
For inserting block in points i found a lots of code.
Thanks again
Miller
Share this post
Link to post
pBe
You mean POINT entity with the lowest Z value? Without knowing the elevation value beforehand, it would be impossible to include a Z value using the SSGET filter. You may have to select ALL points then iterate thru the selectiion one by one.
or are you wanting Z values less than a given elevation? Now this makes more sense.
Share this post
Link to post
Miller87
I try to explain better: you have ,as shown in picture, lots of point in space and also in Z coordinate.
I think you may have two cases:
1) Unique point in (x,y,z) ---> save that point in wanted selection.
For Example: P1 (0, 2, 4) P2 (1, 5, 2) P3 (1, 5, 6) P4 (2, 5, 10)
Select P1, P4; --> ADDSEL
2) Many point with equal x,y, filter selection and save only the one with the lowest value Z.
Select P2 P3; search for minimum Z, add to selection ony P2. --> ADDSEL
Result: LIST with P1, P2, P4
Maybe comparing the coordinate of the point within two while.
Is that possible?
Share this post
Link to post
pBe
Is that possible?
Yes, That is possible, what i'm saying was it is NOT possible in SSGET filter (below)
I will write a short code.. hang on... I dont understand item nos. 1
Share this post
Link to post
Miller87
There may be points that you cannot compare Z coordinates, for example P1 P4, because they have different x and y.
In that case the points P1 P4 are the lowerest in Z position and they must be added at the selection.
I think the comparison in Z position must be effected only for points with equal x and y coordinates.
Thanks again
Share this post
Link to post
hanhphuc
There may be points that you cannot compare Z coordinates...
we only can filter Z by comparing an assumed minimum value, with rational test =etc..
(defun foo ( opr Z)[color="green"]
; operator: = , /= , < , <= , > , >= etc..
; Z = reference elevation[/color]
(ssget ":L" (mapcar 'cons '( 0 -4 10 )
(list  "POINT" (strcat "*,*," opr) (list 0.0 0.0 Z) )))
;example:
(setq ss  ([color="blue"]foo[/color] "[color="red"]<=[/color]" [b]0.0[/b])) [color="green"]; only filter point elevations less than or equal to 0.0 [/color]
Edited by hanhphuc
Thanx Tharwat: remove logical "<AND"
Share this post
Link to post
Tharwat
hanhphuc
Won't this be enough ? :)
(ssget ":L" (list '(0 . "POINT") (cons -4 (strcat "*,*," opr))(list 10 0.0 0.0 Z)))
Share this post
Link to post
pBe
That is exactly what i meant by this:
So in this case, SSGET filter is out of the window. You need to go through the entire selection to do a comparison. dont have CAD with me right now, but it should be easy :)
Share this post
Link to post
hanhphuc
hanhphuc
Thanx Tharwat, 3rd eyes are sharp :lol:
Share this post
Link to post
hanhphuc
1+ agree :)
Share this post
Link to post
Tharwat
Learning C sharp language gives power :P although I am facing lots of obstacles and high jumps on the way but will never give up . :lol:
Share this post
Link to post
pBe
Try this
(defun c:demo ( / coords pionts i crd a b c addsel)
;;		Selec POINT entities on screen		 	;;
     (if (setq coords nil addsel (ssadd)
               points (ssget '((0 . "POINT"))))
;;	Collect all coordinates of selected POINT entity	;;
(repeat (setq i (sslength points))
               (setq crd (cdr
		(Assoc 10 (entget (setq e (ssname points (setq i (1- i))))))))
               (Setq coords (cons (list
                                        (list (car crd)(cadr crd))
                                        (last crd)  e) coords ))
;;Test for duplicate X Y coordinate and pass to variable ADDSEL;;
(while coords
	(setq a (Car coords))(setq xy (car a))
               (if (Setq b (vl-remove-if-not
                             '(lambda (x) (setq c (Car x))(equal xy c))
			(cdr coords)))
                   	(setq order (vl-sort-i  (setq b (cons a b))
                             '(lambda (m n) (< (cadr m)(cadr n)))))
                       (setq a (nth (vl-position 0 order) b))
                       (setq coords (vl-remove-if '(lambda (o)
                                      (member o b)) coords))
                   (setq coords (cdr coords))
                   (ssadd (last a) Addsel)
     (sssetfirst nil addsel)
Not sure if this is what you want though :unsure:
Share this post
Link to post
Miller87
hanhphuc
Close enough to my purpose!!
Thanks anyway
Try this
               (setq crd (cdr
(while coords
			(cdr coords)))
WOWWWWW!!! Impressive!!! :shock:
That's exactly what I need!
Thanks pBe
Share this post
Link to post
pBe
Thanks pBe
Good for you and You are welcome Miller87 :)
Share this post
Link to post
sudam
how can i show all Z value in autocad , as i need bellow screen.
Share this post
Link to post
dlanorh
Try this. You need to set the textsize to the required size before starting.
(defun c:LABZ ( / ms l_ss cnt ent vtx p_lst txt c_pt)
  (setq ms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
  (prompt "\nSelect 3D Lines : ")
  (setq l_ss (ssget "_X" '((0 . "POLYLINE") (-4 . "&=") (70 . 8))))
  (repeat (setq cnt (sslength l_ss))
    (setq ent (ssname l_ss (setq cnt (1- cnt)))
          vtx (entnext ent)
    );end_setq
    (while (/= (cdr (assoc 0 (setq e_lst (entget vtx)))) "SEQEND")
      (setq p_lst (cons (cdr (assoc 10 e_lst)) p_lst)
            vtx (entnext vtx)
      );end_setq
    );end_while
    (foreach pt p_lst
      (setq txt (rtos (caddr pt) 2 3))
      (vla-addtext ms txt (vlax-3d-point pt) (getvar 'textsize))
    );end_foreach
  );end_repeat
Share this post
Link to post
BIGAL
dlanorh dont forget 3dlines as no dwg can not check. Can do a list of all points sort x&y then remove duplicates so text is not twice.
; sorts on 1st two items
(setq lst (vl-sort lst '(lambda (x y)
(cond
((= (cadr x)(cadr y))
(< (car x)(car y)))
((< (cadr x)(cadr y)))
Share this post
Link to post
