Problem Fillet Edges with variable radius
Aleks-117
Hi everyone, I need help with a problem, i speak a little english so i'll try explain me, I need fillet (round) this edges:
I tried with manual Fillet/Constant radius and Variable Radius and the result its not satisfactory because the vertex its not perfect, the vertex have imperfections like this:
This is with Variable radius:
As you seen, the vertex have a sinking surface, and i need the all surfaces/Edges join in a one vertex, I dont care if the radius of the edges is variable.
If you need the model i can provide it.
Thanks for your help.
....I dont know how i can upload the file on this site.
Drag the roll-up bar to the top of the feature tree - hiding all features.
Save the file in this rolled-up state.
Right click on the filename and select Send to Compressed (zipped) Folder.
Reply this thread and click Go Advanced in lower right corner.
Click the attach paperclip and attach the *.zip file here.
Thank you for your help and here is the model
Stellar war Ship.zip
