gamulj
Lisp for Layout name to block attribute
gamulj
Hi to all!
I'am building the title block (block with attributes) and I need a routine that will automatically read layout name, in multi layout dwg, and write it into block attribute „LAYOUT“ for every layout. Field with Ctab doesn't suits my needs...:(
Is something like this possible?
Thanks!
Share this post
Link to post
Tharwat
Yes it is possible .
What is the name of your attributed title block ?
Share this post
Link to post
gamulj
Hi Tharwat!
The name of block is TITLEBLOCK.
Share this post
Link to post
Tharwat
Here we go , try this program .
(defun c:Test  nil
 ;;    Tharwat 20.05.2015        ;;
 ;;    Modify Title Blocks that have     ;;
 ;;    Tag name "LAYOUT" wiht its    ;;
 ;;    location is each Layout's Name    ;;
 (vlax-for x  (vla-get-layouts (vla-get-ActiveDocument (vlax-get-acad-object)))
   (if (/= (vla-get-name x) "Model")
     (vlax-for b  (vla-get-block x)
       (and (eq (vla-get-objectname b) "AcDbBlockReference")
            (eq (vla-get-effectivename b) "TILTEBLOCK")
            (vl-some
              '(lambda (a)
                 (if
                   (eq "LAYOUT" (strcase (vla-get-tagstring a)))
                    (vla-put-textstring a (vla-get-name x))
              (vlax-invoke b 'getattributes)
 )(vl-load-com)
Share this post
Link to post
gamulj
I will try,
Thanks!
Share this post
Link to post
Tharwat
I will try,
Thanks!
Okay , I will be waiting for your try and reply .
Share this post
Link to post
gamulj
Works great!
Is there a way to make lisp automatically recall on open/save or refresh?
Thanks a million!!!
Share this post
Link to post
Tharwat
Works great!
Thanks a million!!!
Excellent . You are most welcome .
You must be in need of running the program on many drawing files . mustn't you ?
Open and save commands shouldn't work , so you need to a third party program to do processing on a list of drawing files .
Share this post
Link to post
gamulj
Exactly!
You know some?
Share this post
Link to post
Tharwat
If you don't have that much of files to implement the program on , just add this (c:Test) to the program after the last parenthesis and add the lisp file to the briefcase of the appload command then just open the drawings you want to run the program in and the program should run automatically and do the job solely then just save and close the drawing to have the new changes saved .
Share this post
Link to post
gamulj
Works perfectly:)
Tharwat, you made my day!
Thanks again!
Share this post
Link to post
Tharwat
Works perfectly:)
Thanks again!
You are most welcome . :thumbsup:
Share this post
Link to post
ramcharger318
Can this be modified to use in a field to get the current tab's name? The CTAB variable doesn't work with data extractions.
Share this post
Link to post
Tharwat
Try this mods.
(defun c:Test (/ doc )
 ;; Tharwat - 29.Nov.2016 ;;
 (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (vlax-for x  (vla-get-layouts doc)
            (vl-some
              '(lambda (a)
                 (and (eq "LAYOUT" (strcase (vla-get-tagstring a)))
                     (vla-put-textstring a "%<\\AcVar ctab>%") t)
 (vla-regen doc acAllViewports)
 )(vl-load-com)
Share this post
Link to post
ramcharger318
I'm not sure how to use it. I tried copying it into the diesel expression in the field, but it says invalid field code.
I have part files that use the layout name in the part name, so that the name is automated. However, when a data extraction is done, it only uses that last saved tab.
Share this post
Link to post
Tharwat
Just be sure to copy all posted codes above to a new txt file and save it with an extension of .lsp then back to AutoCAD and type the command name: APPLOAD or AP then selected the lisp file, then finally type test to run the lisp routine and you should have the block name "TITLEBLOCK" modified with its related Layout name that is resides in.
Share this post
Link to post
ramcharger318
I'm trying to avoid user interaction. When the user/draftsperson creates a new part, I don't want to have to rely on that person to run the command. The part name attribute has the filename variable and CTAB variable plus an increasing number to identify the part. So if that part is in the VM file on the "3" tab the part would be VM-3-X, where the x is any number.
Your code extracts the layout name without the use of the CTAB variable, and I would like to put that into a field in a attribute, maybe via a diesel expression.
Share this post
Link to post
