Modify Xref list
feargt
Hi,
I have a list of Xrefs
Xref_1 Xref_2 Xref_3_ELC Xref_4_ELC Xref_........
I want to modify the list to only include items that have_ELC at the end.
even better would be if i could only add Xrefs to my list that have _ELC at the end.
both attempts below do not succeed.
any ideas?
(defun c:findxref (/ td xrf)
 (setq XrfM nil)
(while (setq td (tblnext "BLOCK" (not td)))
(and (= (logand (cdr (assoc 70 td)) 4) 4)
(setq xrf (cons (strcase (cdr (assoc 2 td))) xrf))
(print xrf)
;attempt with Vl-remove
(foreach n xrf
  (if (/= (wcmatch n "*_ELC")T) (vlremove n xrf)))
;Create new list
(foreach n xrf
  (if (= (wcmatch n "*_ELC")T) (append n xrfm)))
 (print Xrf)
 (print Xrfm)
Thanks
  • Replies 29
  • feargt
    16
  • Tharwat
    11
  • Lee Mac
    3
Just a hint here .
(if (wcmatch n "*_ELC")
  (setq lst (append lst (list n)))
Edited by Tharwat
missing function added
Thanks for the hint but
it's just not happening for me, what am I missing from your hint?
keeps returning Nil for Xrfm
(defun c:findxref (/ td xrf XrfM)
 (setq XrfM '())
(print xrf)
(foreach n xrf
      (setq XrfM (append  n Xrfm))
 (print Xrfm)
I am sorry , I forgot to add the list function for the append function to work with lists .
So just add the list function for the n variable to be able to append it to the list .
eg.
(foreach n xrf
     (setq XrfM (append Xrfm (list n)))
Rather than removing the unwanted items from the resulting list, I would instead suggest omitting them within the initial loop, e.g.:
(defun c:findxref ( / td xrf xrn )
   (while (setq td (tblnext "block" (not td)))
            (wcmatch (setq xrn (strcase (cdr (assoc 2 td)))) "*_ELC") ;; Must pass this criteria before being added to the list
            (setq xrf (cons xrn xrf))
   (print xrf)
Hi again, related to same why am I getting an error message here
I am trying to retrieve the X value of the Insertion Point of the xrefs in my list,
but it returns an error. If i try Option 2 and enter the Xref Name at Position "n" and only enter that on the command line, then it works. any ideas what I am missing here
(foreach n xrf
[color=red]OPTION 1[/color]
  (setq ss (ssget "X" '((0 . "INSERT")(67 . 0)(2 . n))))
(setq x (car (cdr (assoc 10 (entget ss)))))
[color=red]OPTION 2[/color]
  (setq x (car (cdr (assoc 10 (entget (ssname (ssget "_X" '((2 . n))) 0))))))
(print x)
Thanks Tharwat,
can u possibly explain what ist Happening in the section .....
........(apply 'strcat (mapcar '(lambda (x) (strcat x ",")) xrf))))))
This seems to return only the X value of the first Xref in the list each time and not the x value for the next xref in my list
I would suggest something like:
(defun c:findxref ( / idx ins sel td xrf xrn )
            (setq xrf (vl-list* "," xrn xrf))
   (if (setq sel (ssget "_X" (list '(0 . "INSERT") (cons 2 (apply 'strcat (cdr xrf))))))
           (repeat (setq idx (sslength sel))
               (setq ins (cons (cadr (assoc 10 (entget (ssname sel (setq idx (1- idx)))))) ins))
           (print ins)
       (princ "\nNo xrefs found.")
Thanks Lee for your Version.
might help to explain why I wanted to use for each.
I want to replace the existing xref with two other xrefs, which Need to be inserted at the same Insertion Point (which only varies on the x axis)
so for example.
Replace Xref_1_ELC
with Xref_1_ELC_Sub1 and Xref_1_ELC_Sub2
The new names for the Xref I can get by manipulting the "n"
(setq xrefn (vl-string-subst "_ELC_Sub1" "_ELC" n)))
the replacement I think is not a Problem using (command "_.-xref" .......)
so for example.
Replace Xref_1_ELC
You can add as many as you want in the following program as shown in the program eg. ("old" "new") and you need to save and re-open the drawing to see the changes.
(defun c:test (/ lst fnd pth)
 ;; Tharwat 23.06.2015 ;;
 (setq lst '(([color=red]"Xref_1_ELC"[/color] [color=blue]"Xref_1_ELC_Sub1"[/color]) ([color=red]"Old"[/color] [color=blue]"New"[/color])))
 (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
   (if (and (= :vlax-true (vla-get-isxref blk))
            (setq fnd (assoc (vla-get-name blk) lst))
            (setq pth (findfile (strcat (cadr fnd) ".dwg")))
     (vla-put-path blk pth)
)(vl-load-com)
Thanks Tharwat,
The reason that I was approaching it the way I was with
(foreach n xrf
(setq ss (ssget "_X" (list '(0 . "INSERT")'(67 . 0)(cons 2 (apply 'strcat (mapcar '(lambda (n) (strcat n ",")) xrf))))))
(print x)
is because I dont know the names of the Xrefs, I only know that they end in "_ELC" and that it Needs to be done to about 150 drawings
Which is why I wanted to iterate through each Xref in my list, get the insertion point and use that to insert the new xrefs. Each xref will be replaced with 2 xrefs.
The main problem being that the above which you provided is not returning the Insertion Point for each xref ( as in "n") but returns the insertion point for the first Xref in the list each time instead of iterating through them.
I have not been able to figure this part of the code out
Firstly the mapcar function would append a comma to every name of the xref name that is gathered in the 'xrf" variable , then the apply function with the use of strcat function would gather them as one string to match the criteria needed for the ssget funtion as dxf codes .
eg.
xrf = ("drawing1" "drawing2" "drawing3")
; return: ("drawing1," "drawing2," "drawing3,")
; then using the apply with strcat function to concatenate them all together .
; return: "drawing1,drawing2,drawing3,"
but then should the following not work? I mean should it not print to the command line the X value of the Insertion Point for each xref in Xrf?
assuming xrf = ( "Xref_1_ELC" "Xref_2_ELC")
 (foreach n xrf
   (setq ss (ssget "_X" (list '(0 . "INSERT")'(67 . 0)(cons 2 n))))
    (print ss)
        (setq x (car (cdr (assoc 10 (entget (ssname n 0))))))
    (print x)
Since you know the old and the new replaced one , you can use the codes that I posted in post No# 14
Why you are re-selecting the same block name since that you can make any changes while retrieving it from the block table right away ?
because I am not just replacing it with another Xref, I also need to insert a second Xref at the same Insertion point
With the function vla-put-path would take care of all and using codes much better than using commands as you are planning to.
