tmelancon Posted July 15, 2015 Share Posted July 15, 2015 Hello, I currently use a routine that offsets a line in both directions based on a specified distance in the routine. After we run the command we usually have to select the two offset lines and put them on a specific layer, in this case "Structure". I am trying to just add to the routine so the offset lines are automatically put on that layer for us but for some reason when we run the routine its putting all 3 lines (the original, and the two offset lines) on that layer. Can someone review it over and respond. Thanks (defun C:OFF (/ pickEnt pickObj offDist) (vl-load-com) (setq offDist 0.0812) (while (setq pickEnt (entsel)) (cond ((and pickEnt (setq pickObj (vlax-EName->vla-Object (car pickEnt))) offDist) (vla-put-layer pickObj "STRUCTURE" ) (vla-Offset pickObj offDist) (vla-Offset pickObj (- offDist)) ) ) ;_ end of cond ) ;_ end of while (princ) ) ;_ end of defun Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 15, 2015 Share Posted July 15, 2015 Hi, Be careful to have the layer name "STRUCTURE" into your drawing before running the routine. (defun c:Test (/ o s) (setq o 0.0812) (while (setq s (ssget "_+.:S:E:L" '((0 . "*LINE,CIRCLE,ARC,ELLIPSE")))) (foreach v (list o (- o)) (vla-Offset (vlax-EName->vla-Object (ssname s 0)) v) (vla-put-layer (vlax-EName->vla-Object (entlast)) "STRUCTURE") ) ) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
tmelancon Posted July 15, 2015 Author Share Posted July 15, 2015 I believe I have it now, just took me a little bit of reorganizing of where I was putting the step in and out of current layer. (defun C:OFF (/ pickEnt pickObj offDist OLDLAYR *ERROR*) (vl-load-com) (defun *error* (msg) (if oldlayr (setvar "clayer" oldlayr)) (if msg (prompt msg)) (princ) ) (setq offDist 0.0812) (while (setq oldlayr (getvar "clayer")) (command "._-layer" "s" "STRUCTURE" "") (setq pickEnt (entsel)) (cond ((and pickEnt (setq pickObj (vlax-EName->vla-Object (car pickEnt))) offDist) (vla-put-layer pickObj "STRUCTURE" ) (vla-Offset pickObj offDist) (vla-Offset pickObj (- offDist)) (vla-put-layer pickObj OLDLAYR ) (command "._-layer" "s" oldlayr "") ) ) ;_ end of cond ) ;_ end of while (princ) ) ;_ end of defun Quote Link to comment Share on other sites More sharing options...
tmelancon Posted July 15, 2015 Author Share Posted July 15, 2015 Oh I just noticed you posted.. Wow well its obvious who has better lisp writing skills.. gosh I wish I was that good. I am getting better but definitely a noob when it comes to how I write. meehh:o I really wish I could further advance my lisp knowledge and programming knowledge. Thank you so much for your help it is greatly appreciate!! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 15, 2015 Share Posted July 15, 2015 Oh I just noticed you posted.. Wow well its obvious who has better lisp writing skills.. gosh I wish I was that good. I am getting better but definitely a noob when it comes to how I write. meehh:o I really wish I could further advance my lisp knowledge and programming knowledge. Thank you so much for your help it is greatly appreciate!! You are most welcome . Practice and practice to become experienced guy. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 15, 2015 Share Posted July 15, 2015 Looks like you guys have been posting since I was pulled into a meeting - but I'll post this anyway. This will ensure that the dependent layer is available, handles some misc. entity overrides, supports multiple entity selection, and supports UNDO: (defun c:FOO (/ *error* _Offset acDoc layerName left right ss) (defun *error* (msg) (if ss (vla-delete ss)) (if acDoc (vla-endundomark acDoc)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (defun _Offset (x dir layerName) (foreach y (vlax-invoke x 'offset dir) (vla-put-color y acbylayer) (vla-put-layer y layerName) (vla-put-linetype y "bylayer") ) ) (if (ssget "_:L" '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))) (progn (vla-startundomark (setq acDoc (vla-get-activedocument (vlax-get-acad-object))) ) (vla-add (vla-get-layers acDoc) (setq layerName "STRUCTURE")) (setq left 0.0812 right (- 0.0812) ) (vlax-for x (setq ss (vla-get-activeselectionset acDoc)) (_Offset x left layerName) (_Offset x right layerName) ) ) ) (*error* nil) ) Cheers Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 16, 2015 Share Posted July 16, 2015 Like Black box I would use in the simple code version above (setvar "clayer" "Structure") rather than the long winded command layer method. The VLa-add is a good idea as if exists keeps going else adds. It would be a good library defun so only 1 line required in your code. ; library defun to check if layer exists ; there would be a acdoc defun also (defun addlayer (layername / acdoc) (vla-startundomark (setq acDoc (vla-get-activedocument (vlax-get-acad-object))) ) (vla-add (vla-get-layers acDoc) layerName ) ) ; end defun ; code (addlayer "STRUCTURE") Quote Link to comment Share on other sites More sharing options...
BlackBox Posted July 16, 2015 Share Posted July 16, 2015 Like Black box I would use in the simple code version above (setvar "clayer" "Structure") rather than the long winded command layer method. The VLa-add is a good idea as if exists keeps going else adds. It would be a good library defun so only 1 line required in your code. *Tips hat* - Cheers, dude. The only thing I'd add, and this is my $0.02 (take from it what you like) - is to call *UndoMark from the calling routine, rather than within the sub-function(s); just makes more sense for the code I use here, YMMV. Quote Link to comment Share on other sites More sharing options...
anisimov Posted July 16, 2021 Share Posted July 16, 2021 Hello! Can you please tell me where to add this code to OffInOffOut.lsp to offset the line to another layer? Quote Link to comment Share on other sites More sharing options...
capnsjules Posted May 19, 2023 Share Posted May 19, 2023 On 7/15/2015 at 12:29 PM, BlackBox said: Looks like you guys have been posting since I was pulled into a meeting - but I'll post this anyway. This will ensure that the dependent layer is available, handles some misc. entity overrides, supports multiple entity selection, and supports UNDO: (defun c:FOO (/ *error* _Offset acDoc layerName left right ss) (defun *error* (msg) (if ss (vla-delete ss)) (if acDoc (vla-endundomark acDoc)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (defun _Offset (x dir layerName) (foreach y (vlax-invoke x 'offset dir) (vla-put-color y acbylayer) (vla-put-layer y layerName) (vla-put-linetype y "bylayer") ) ) (if (ssget "_:L" '((0 . "ARC,CIRCLE,ELLIPSE,*LINE"))) (progn (vla-startundomark (setq acDoc (vla-get-activedocument (vlax-get-acad-object))) ) (vla-add (vla-get-layers acDoc) (setq layerName "STRUCTURE")) (setq left 0.0812 right (- 0.0812) ) (vlax-for x (setq ss (vla-get-activeselectionset acDoc)) (_Offset x left layerName) (_Offset x right layerName) ) ) ) (*error* nil) ) Is it possible for this routine to prompt a user to pick an offset side of the selected object first? The other side picking up the negative value. Cheers Quote Link to comment Share on other sites More sharing options...
ronjonp Posted May 19, 2023 Share Posted May 19, 2023 (edited) @capnsjules ;; Change this ;;; (setq left 0.0812 ;;; right (- 0.0812) ;;; ) ;; To this (setq left (getdist "\nSpecify offset distance: ") right (- left) ) Edited May 19, 2023 by ronjonp Quote Link to comment Share on other sites More sharing options...
