Thomas Baxter Posted August 6, 2015 Share Posted August 6, 2015 When I create a dashed line model space and change to paper space in changes to a solid line and prints a a solid line? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 6, 2015 Share Posted August 6, 2015 Check LTSCALE, PSLTSCALE, MSLTSCALE Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 6, 2015 Share Posted August 6, 2015 Welcome to CADTutor Thomas. You might want to check your MEASUREMENT system variable setting too. If your drawing is Imperial based, the setting should be , and if Metric it should be Quote Link to comment Share on other sites More sharing options...
Thomas Baxter Posted August 6, 2015 Author Share Posted August 6, 2015 system variable was set (0) Quote Link to comment Share on other sites More sharing options...
Squirltech Posted August 6, 2015 Share Posted August 6, 2015 Check LTSCALE, PSLTSCALE, MSLTSCALE This is a recurring topic at my office too. 9 out of 10 times PSLTSCALE is the culprit. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 6, 2015 Share Posted August 6, 2015 A bit more if you use the psltscale 0 it matches paperspace and modelspace in terms of look. The ltscale is a global factor for all lines. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 7, 2015 Share Posted August 7, 2015 A little more grist for the mill, from the SYSVDLG description. Quote Link to comment Share on other sites More sharing options...
Thomas Baxter Posted August 7, 2015 Author Share Posted August 7, 2015 It worked Thank you Tom Baxter Quote Link to comment Share on other sites More sharing options...
