Kowal Posted August 7, 2015 Share Posted August 7, 2015 How to get a point from the list with the largest or smallest x-coordinate. Example list of points. '((1.0 0.0) (2.2 2.0) (-2.0 0.0) ...) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 7, 2015 Share Posted August 7, 2015 One way : (apply 'max (mapcar 'car '((1.0 0.0) (2.2 2.0) (-2.0 0.0)))) (apply 'min (mapcar 'car '((1.0 0.0) (2.2 2.0) (-2.0 0.0)))) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 7, 2015 Share Posted August 7, 2015 Another to sort the list from bigger to smaller for the max and visa versa . Max eg. (car (vl-sort (mapcar 'car '((1.0 0.0) (2.2 2.0) (-2.0 0.0))) '>)) Min eg. (car (vl-sort (mapcar 'car '((1.0 0.0) (2.2 2.0) (-2.0 0.0))) '<)) Quote Link to comment Share on other sites More sharing options...
Kowal Posted August 7, 2015 Author Share Posted August 7, 2015 Thanks for the reply Tharwat. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 7, 2015 Share Posted August 7, 2015 Thanks for the reply Tharwat. You're welcome anytime. Quote Link to comment Share on other sites More sharing options...
Kowal Posted August 7, 2015 Author Share Posted August 7, 2015 Your code is very good but I need to get the x and y coordinate Returns' (xmin y). Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 7, 2015 Share Posted August 7, 2015 Your code is very good but I need to get the x and y coordinate Just replace the function car with cadr in my first example to get y coordinates . Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 7, 2015 Share Posted August 7, 2015 Should the result be a member of the list? I.e. For a list of points: ((1 4 0) (3 2 0) (4 5 0)) Should the function return (1 4 0) or (1 2 0)? Quote Link to comment Share on other sites More sharing options...
rlx Posted August 7, 2015 Share Posted August 7, 2015 (edited) ok geniusses , now you're all awake , some time ago i wrote this to sort a selectionset by coordinates. But i stink it can shorter en more intelligent (but that's obvious in my case ;-) ;el = elist , xl = x , yl = y , ml = matrix , sl = sorted elist (defun LG_SortSelectionSet ( ss / e el i xl yl ml sl) (if (and ss (> (sslength ss) 1)(setq i 0)) (progn ;ss -> elist ( ((ip)e1) ((ip)e2) .. ) (while (setq e (ssname ss i)) (setq el (append el (list (list (getip e) e))) i (1+ i))) (setq xl (vl-sort (rdup (mapcar 'caar el)) '<) yl (vl-sort (rdup (mapcar 'cadar el)) '>)) (foreach y yl (foreach x xl (setq ml (append ml (list (list x y)))))) (setq sl (no-nil (mapcar '(lambda (x) (if (assoc x el)(cadr (assoc x el)))) ml)))))) (defun rdup ( i / o );remove duplicates (vl-remove-if '(lambda (x) (cond ((vl-position x o) t) ((setq o (cons x o)) nil))) i)) (defun getip (e);get insertionpoint (list (cadr (assoc 10 (entget e)))(caddr (assoc 10 (entget e))))) (defun no-nil (lst) (apply 'append (subst nil (list nil) (mapcar 'list lst)))) in order to keep the first code more readable i created a couple of little subs like rdup etc (yes I know , vanilla) What is does is first make a list of all x coordinates , same for y , then remove duplicates , sort the list and then see which combinations actually excist in selection set. It does work but i suspect there must be a more efficient way. (right now i am a little bit lazy by asking you...) gr. Rlx Edited August 7, 2015 by rlx Quote Link to comment Share on other sites More sharing options...
Kowal Posted August 7, 2015 Author Share Posted August 7, 2015 List: '((1 4 0) (3 2 0) (4 5 0)) Result min x coordinate: '(1 4 0) Quote Link to comment Share on other sites More sharing options...
David Bethel Posted August 7, 2015 Share Posted August 7, 2015 I use something like this a lot for automated dimensions for line drawings. It maybe of some use : [b][color=BLACK]([/color][/b]defun c:linebs [b][color=FUCHSIA]([/color][/b]/ ss i en ed p1 p2 pl rl pt minx miny maxx maxy minxminy minxmaxy maxxminy maxxmaxy minyminx minymaxx maxyminx maxymaxx[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]defun massoc [b][color=NAVY]([/color][/b]key alist / nlist[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]foreach x alist [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]eq key [b][color=BLUE]([/color][/b]car x[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq nlist [b][color=BLUE]([/color][/b]cons [b][color=RED]([/color][/b]cdr x[b][color=RED])[/color][/b] nlist[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]reverse nlist[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]defun rnd_gvtol [b][color=NAVY]([/color][/b]value[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]* gv_tol [b][color=MAROON]([/color][/b]fix [b][color=GREEN]([/color][/b]/ [b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]if [b][color=PURPLE]([/color][/b]minusp value[b][color=PURPLE])[/color][/b] - +[b][color=RED])[/color][/b] value [b][color=RED]([/color][/b]* gv_tol 0.5[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] gv_tol[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq gv_tol 0.001[b][color=FUCHSIA])[/color][/b][color=#8b4513];;GLOBAL TOLERANCE VALUE[/color] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][color=BLUE]([/color][/b]cons 8 [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CLAYER"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] p1 [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]rnd_gvtol [b][color=RED]([/color][/b]cadr [b][color=PURPLE]([/color][/b]assoc 10 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]rnd_gvtol [b][color=RED]([/color][/b]caddr [b][color=PURPLE]([/color][/b]assoc 10 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] pl [b][color=GREEN]([/color][/b]cons p1 pl[b][color=GREEN])[/color][/b] rl [b][color=GREEN]([/color][/b]cons [b][color=BLUE]([/color][/b]reverse p1[b][color=BLUE])[/color][/b] rl[b][color=GREEN])[/color][/b] p2 [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]rnd_gvtol [b][color=RED]([/color][/b]cadr [b][color=PURPLE]([/color][/b]assoc 11 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]rnd_gvtol [b][color=RED]([/color][/b]caddr [b][color=PURPLE]([/color][/b]assoc 11 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] pl [b][color=GREEN]([/color][/b]cons p2 pl[b][color=GREEN])[/color][/b] rl [b][color=GREEN]([/color][/b]cons [b][color=BLUE]([/color][/b]reverse p2[b][color=BLUE])[/color][/b] rl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq minx [b][color=NAVY]([/color][/b]apply 'min [b][color=MAROON]([/color][/b]mapcar 'car pl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] maxx [b][color=NAVY]([/color][/b]apply 'max [b][color=MAROON]([/color][/b]mapcar 'car pl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] miny [b][color=NAVY]([/color][/b]apply 'min [b][color=MAROON]([/color][/b]mapcar 'car rl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] maxy [b][color=NAVY]([/color][/b]apply 'max [b][color=MAROON]([/color][/b]mapcar 'car rl[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] minyminx [b][color=NAVY]([/color][/b]apply 'min [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc minx pl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] maxyminx [b][color=NAVY]([/color][/b]apply 'max [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc minx pl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] minymaxx [b][color=NAVY]([/color][/b]apply 'min [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc maxx pl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] maxymaxx [b][color=NAVY]([/color][/b]apply 'max [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc maxx pl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] minxminy [b][color=NAVY]([/color][/b]apply 'min [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc miny rl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] maxxminy [b][color=NAVY]([/color][/b]apply 'max [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc miny rl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] minxmaxy [b][color=NAVY]([/color][/b]apply 'min [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc maxy rl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] maxxmaxy [b][color=NAVY]([/color][/b]apply 'max [b][color=MAROON]([/color][/b]mapcar 'car [b][color=GREEN]([/color][/b]massoc maxy rl[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]foreach v [b][color=NAVY]([/color][/b]list [b][color=MAROON]([/color][/b]list [color=#2f4f4f]"minx"[/color] [color=#2f4f4f]"miny"[/color][b][color=MAROON])[/color][/b][b][color=MAROON]([/color][/b]list [color=#2f4f4f]"minx"[/color] [color=#2f4f4f]"maxy"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]list [color=#2f4f4f]"maxx"[/color] [color=#2f4f4f]"miny"[/color][b][color=MAROON])[/color][/b][b][color=MAROON]([/color][/b]list [color=#2f4f4f]"maxx"[/color] [color=#2f4f4f]"maxy"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]list [color=#2f4f4f]"minx"[/color] [color=#2f4f4f]"minyminx"[/color][b][color=MAROON])[/color][/b][b][color=MAROON]([/color][/b]list [color=#2f4f4f]"minx"[/color] [color=#2f4f4f]"maxyminx"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]list [color=#2f4f4f]"maxx"[/color] [color=#2f4f4f]"minymaxx"[/color][b][color=MAROON])[/color][/b][b][color=MAROON]([/color][/b]list [color=#2f4f4f]"maxx"[/color] [color=#2f4f4f]"maxymaxx"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]list [color=#2f4f4f]"minxminy"[/color] [color=#2f4f4f]"miny"[/color][b][color=MAROON])[/color][/b][b][color=MAROON]([/color][/b]list [color=#2f4f4f]"maxxminy"[/color] [color=#2f4f4f]"miny"[/color][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]list [color=#2f4f4f]"minxmaxy"[/color] [color=#2f4f4f]"maxy"[/color][b][color=MAROON])[/color][/b][b][color=MAROON]([/color][/b]list [color=#2f4f4f]"maxxmaxy"[/color] [color=#2f4f4f]"maxy"[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq pt [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]eval [b][color=BLUE]([/color][/b]read [b][color=RED]([/color][/b]car v[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]eval [b][color=BLUE]([/color][/b]read [b][color=RED]([/color][/b]cadr v[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]entmake [b][color=MAROON]([/color][/b]list [b][color=GREEN]([/color][/b]cons 0 [color=#2f4f4f]"TEXT"[/color][b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]cons 10 pt[b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]cons 11 pt[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]cons 1 [b][color=BLUE]([/color][/b]strcat [b][color=RED]([/color][/b]car v[b][color=RED])[/color][/b] [color=#2f4f4f]","[/color] [b][color=RED]([/color][/b]cadr v[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]cons 7 [b][color=BLUE]([/color][/b]getvar [color=#2f4f4f]"TEXTSTYLE"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]cons 40 1.8[b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]cons 41 0.9[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]cons 62 1[b][color=GREEN])[/color][/b][b][color=GREEN]([/color][/b]cons 72 4[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David TEST.DWG Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 7, 2015 Share Posted August 7, 2015 List:'((1 4 0) (3 2 0) (4 5 0)) Result min x coordinate: '(1 4 0) A few ways to tackle this: (defun f1 ( l ) (car (vl-sort l '(lambda ( a b ) (< (car a) (car b))))) ) _$ (f1 '((1 4 0) (3 2 0) (4 5 0))) (1 4 0) (defun f2 ( l / r ) (setq r (car l)) (foreach x (cdr l) (if (< (car x) (car r)) (setq r x))) r ) _$ (f2 '((1 4 0) (3 2 0) (4 5 0))) (1 4 0) (defun f3 ( l ) (if (cdr l) (if (< (caar l) (caadr l)) (f3 (cons (car l) (cddr l))) (f3 (cdr l)) ) (car l) ) ) _$ (f3 '((1 4 0) (3 2 0) (4 5 0))) (1 4 0) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 7, 2015 Share Posted August 7, 2015 What is does is first make a list of all x coordinates , same for y , then remove duplicates , sort the list and then see which combinations actually excist in selection set. The output would depend on whether you are looking to sort by x-coordinate and then by y-coordinate (or vice-versa), or whether you are looking to sort by distance from the origin. For the latter, I would suggest something along the lines of: (defun sortselset ( s / e i l p ) (repeat (setq i (sslength s)) (setq e (ssname s (setq i (1- i))) p (cons (cdr (assoc 10 (entget e))) p) l (cons e l) ) ) (mapcar '(lambda ( n ) (nth n l)) (vl-sort-i p '(lambda ( a b ) (< (distance '(0 0) a) (distance '(0 0) b)))) ) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 7, 2015 Share Posted August 7, 2015 A generic sorting function is likely more useful, e.g. sorting by x-coordinate: (defun sortselset ( s f / e i l p ) (repeat (setq i (sslength s)) (setq e (ssname s (setq i (1- i))) p (cons (cdr (assoc 10 (entget e))) p) l (cons e l) ) ) (mapcar '(lambda ( n ) (nth n l)) (vl-sort-i p f)) ) (sortselset <selection-set> '(lambda ( a b ) (< (car a) (car b)))) Quote Link to comment Share on other sites More sharing options...
rlx Posted August 7, 2015 Share Posted August 7, 2015 I will have a look at your code Lee , but not now : weekend! :-) the natural way is up-down , left-right so that is what I built in. thanx Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 7, 2015 Share Posted August 7, 2015 I will have a look at your code Lee , but not now : weekend! :-) You're welcome! the natural way is up-down , left-right so that is what I built in. For up-down/left-right: (sortselset <selection-set> '(lambda ( a b ) (if (equal (cadr a) (cadr b) 1e- (< (car a) (car b)) (> (cadr a) (cadr b)) ) ) ) Quote Link to comment Share on other sites More sharing options...
rlx Posted August 8, 2015 Share Posted August 8, 2015 You're welcome! For up-down/left-right: (sortselset <selection-set> '(lambda ( a b ) (if (equal (cadr a) (cadr b) 1e- (< (car a) (car b)) (> (cadr a) (cadr b)) ) ) ) looks like exactly what the dragon , pardon , doctor ordered , thanx Lee , real smooth Quote Link to comment Share on other sites More sharing options...
catoscuro Posted August 10, 2015 Share Posted August 10, 2015 hello David, you could upload the original routine linebs Thanks Quote Link to comment Share on other sites More sharing options...
David Bethel Posted August 10, 2015 Share Posted August 10, 2015 (edited) hello David, you could upload the original routine linebs Thanks This is a stand alone auto_dimension of a sort. These ARE NOT associative DIMENSION entities. There are several personal settings that can be manipulated to your tastes (defun c:minmax (/ ss i en ed p pl rl hf vf tz minx miny maxx maxy minxminy minxmaxy maxxminy maxxmaxy minyminx minymaxx maxyminx maxymaxx ll lr ur ul llx lly lrx lry urx ury ulx uly) ;(trace dim_auto) (defun massoc (key alist / nlist) (foreach x alist (if (eq key (car x)) (setq nlist (cons (cdr x) nlist)))) (reverse nlist)) (defun round (value to) (setq to (abs to)) (* to (fix (/ ((if (minusp value) - +) value (* to 0.5)) to)))) (if (not (setq ss (ssget "X" (list (cons 0 "LINE")(cons 8 (getvar "CLAYER")))))) (alert (strcat "No LINEs Found On Current LAyer " (getvar "CLAYER"))) (progn (setq i 0) (while (setq en (ssname ss i)) (setq ed (entget en)) (foreach g '(10 11) (setq p (list (round (cadr (assoc g ed)) 0.1) (round (caddr (assoc g ed)) 0.1)) pl (cons p pl) rl (cons (reverse p) rl))) (setq i (1+ i))) (setq minx (apply 'min (mapcar 'car pl)) maxx (apply 'max (mapcar 'car pl)) miny (apply 'min (mapcar 'car rl)) maxy (apply 'max (mapcar 'car rl)) minyminx (apply 'min (mapcar 'car (massoc minx pl))) maxyminx (apply 'max (mapcar 'car (massoc minx pl))) minymaxx (apply 'min (mapcar 'car (massoc maxx pl))) maxymaxx (apply 'max (mapcar 'car (massoc maxx pl))) minxminy (apply 'min (mapcar 'car (massoc miny rl))) maxxminy (apply 'max (mapcar 'car (massoc miny rl))) minxmaxy (apply 'min (mapcar 'car (massoc maxy rl))) maxxmaxy (apply 'max (mapcar 'car (massoc maxy rl))) ll (list minx miny 0) lr (list maxx miny 0) ur (list maxx maxy 0) ul (list minx maxy 0) llx (list minxminy miny 0) lly (list minx minyminx 0) lrx (list maxxminy miny 0) lry (list maxx minymaxx 0) urx (list maxxmaxy maxy 0) ury (list maxx maxymaxx 0) ulx (list minxminy maxy 0) uly (list minx maxyminx 0)) (setq tz (getvar "TEXTSIZE") vf (fix (* tz 4)) hf (fix (* tz 3))) ;;;ARG -> dim_auto "H"/"V" point1 point2 text_vector_point text_size ;;;TOP (dim_auto "H" uly ulx (list 0 (+ maxy hf)) tz) (dim_auto "H" ulx urx (list 0 (+ maxy hf)) tz) (dim_auto "H" urx ury (list 0 (+ maxy hf)) tz) ;;;BOTTOM (dim_auto "H" lly llx (list 0 (- miny hf)) tz) (dim_auto "H" llx lrx (list 0 (- miny hf)) tz) (dim_auto "H" lrx lry (list 0 (- miny hf)) tz) ;;;LEFT (dim_auto "V" llx lly (list (- minx vf) 0) tz) (dim_auto "V" lly uly (list (- minx vf) 0) tz) (dim_auto "V" uly ulx (list (- minx vf) 0) tz) ;;;RIGHT (dim_auto "V" lrx lry (list (+ maxx vf) 0) tz) (dim_auto "V" lry ury (list (+ maxx vf) 0) tz) (dim_auto "V" ury urx (list (+ maxx vf) 0) tz) ;;;OVERALL (dim_auto "H" uly ury (list 0 (+ maxy hf hf)) tz) (dim_auto "H" lly lry (list 0 (- miny hf hf)) tz) (dim_auto "V" llx ulx (list (- minx vf vf) 0) tz) (dim_auto "V" lrx urx (list (+ maxx vf vf) 0) tz))) (prin1)) ;;;ENTMAKE A SIMPLE DIMENSION BLOCK WITH ATTRIBUTES ;;;ARG -> dim_dir "H"/"V" point1 point2 text_vector_point text_size ;;;RET -> ename (defun dim_auto (dr pt1 pt2 tp ts / sp1 sp2 te1 te2 ofa scp txv tcp lcp ep1 ep2 bn sdef ara txs ta flg dsuf hs) ;;;PERSONALIZE SETTINGS (setvar "DIMZIN" (setvar "UNITMODE" 1) (setvar "ELEVATION" 0.0) (setvar "THICKNESS" 0) (setvar "LUNITS" 2) (setvar "LUPREC" 2) (setq dsuf "\"") ;;;DIMENSION SUFFIX ( Inch Mark ) (setq tp (list (round (car tp) 1) (round (cadr tp) 1))) (cond ((= dr "H") (cond ((< (cadr tp) (cadr pt1)) (setq ta -0.5)) ((> (cadr tp) (cadr pt1)) (setq ta 0.5)) (T (setq ta 0.5))) (setq flg (if (< (cadr tp) (cadr pt1)) "MR" "ML")) ;;; ATDEF FLAG ROTATION ) ((= dr "V") (cond ((< (car tp) (car pt1)) (setq ta -0.5)) ((> (car tp) (car pt1)) (setq ta 0.5)) (T (setq ta 0.5)))) (T (setq ta 0.5))) (defun pte (p) (list (car p) (cadr p) (getvar "ELEVATION"))) (entmake (list (cons 0 "BLOCK")(cons 10 pt1)(cons 2 "*U")(cons 70 1))) ;;;VERTICAL DIM LINES (and (= dr "V") (setq hs (/ ts 1.5) txv (abs (- (cadr pt1) (cadr pt2))) ofa (if (>= (car tp) (car pt1)) 0 1) sp1 (pte (polar pt1 (* pi ofa) hs)) te1 (pte (list (car tp) (cadr sp1) (caddr sp1))) ep1 (pte (polar te1 (* pi ofa) hs)) sp2 (pte (polar pt2 (* pi ofa) hs)) te2 (pte (list (car tp) (cadr sp2) (caddr sp2))) ep2 (pte (polar te2 (* pi ofa) hs)) tcp (pte (polar te1 (angle te1 te2) (* (distance te1 te2) 0.5))) scp (pte (polar tcp (* pi 1.5) (* ts 3))) ara 0 txs 0.9) (entmake (list (cons 0 "LINE")(cons 62 1)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 sp1)(cons 11 ep1))) (entmake (list (cons 0 "LINE")(cons 62 1)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 sp2)(cons 11 ep2))) (if (> txv (* ts 2)) (progn (entmake (list (cons 0 "LINE")(cons 62 2)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 (polar te1 (angle te2 te1) hs)) (cons 11 (polar tcp (angle te2 te1) ts)))) (entmake (list (cons 0 "LINE")(cons 62 2)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 (polar te2 (angle te1 te2) hs)) (cons 11 (polar tcp (angle te1 te2) ts))))) (entmake (list (cons 0 "LINE")(cons 62 2)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 (polar te1 (angle te2 te1) hs)) (cons 11 (polar te2 (angle te1 te2) hs)))))) ;;;HORIZONTAL DIM LINES (and (= dr "H") (setq hs (/ ts 1.5) txv (abs (- (car pt1) (car pt2))) ofa (if (>= (cadr tp) (cadr pt1)) 0.5 1.5) sp1 (pte (polar pt1 (* pi ofa) hs)) te1 (pte (list (car sp1) (cadr tp) (caddr sp1))) ep1 (pte (polar te1 (* pi ofa) hs)) sp2 (pte (polar pt2 (* pi ofa) hs)) te2 (pte (list (car sp2) (cadr tp) (caddr sp2))) ep2 (pte (polar te2 (* pi ofa) hs)) lcp (pte (list (* 0.5 (+ (nth 0 te1) (nth 0 te2))) (* 0.5 (+ (nth 1 te1) (nth 1 te2))))) tcp (pte (polar lcp (* pi 0.5) ts)) scp (pte (polar lcp (* pi 1.5) ts)) ara 0) (entmake (list (cons 0 "LINE")(cons 62 1)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 sp1)(cons 11 ep1))) (entmake (list (cons 0 "LINE")(cons 62 1)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 sp2)(cons 11 ep2))) (entmake (list (cons 0 "LINE")(cons 62 2)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 (polar te1 (angle te2 te1) hs)) (cons 11 (polar te2 (angle te1 te2) hs))))) ;;;TICK MARKS (entmake (list (cons 0 "LINE")(cons 62 3)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 (polar te1 (* pi 0.25) hs)) (cons 11 (polar te1 (* pi 1.25) hs)))) (entmake (list (cons 0 "LINE")(cons 62 3)(cons 6 "CONTINUOUS")(cons 8 "0") (cons 10 (polar te2 (* pi 0.25) hs)) (cons 11 (polar te2 (* pi 1.25) hs)))) (setq bn (entmake (list (cons 0 "ENDBLK")))) ;;;CURRENT TEXT VALUES (setq sdef (tblsearch "STYLE" (getvar "TEXTSTYLE"))) ;;;ROTATE SMALL VALUES (cond ((= dr "V") (setq ara 0) (if (< txv (* ts 2)) (setq tcp (polar tcp (if (> (car tp) (car sp1)) 0 pi) (* (+ 3 (strlen (rtos txv 2))) ts 0.5))))) ((and (> (* (strlen (rtos txv 2)) ts 1.1) txv) (>= txv (* ts 2))) (setq ara 0) (setq txs 0.) ((< txv (* ts 2)) (setq tcp (polar tcp (* pi ta) (+ ts (* (strlen (rtos txv 2)) (if (= flg "ML") 0.0 1.25) ts)))) (setq scp (polar scp (* pi ta) (+ ts (* (strlen (rtos txv 2)) 0.5 ts)))) (setq ara (* pi 0.5)) (setq txs 1)) (T (setq ara 0 txs 0.9 flg "MC"))) ;;;MAKE AN INSET WITH ATTRIBUTES (entmake (list (cons 0 "INSERT")(cons 2 bn)(cons 10 (pte pt1))(cons 66 1))) (entmake (list (cons 0 "ATTRIB")(cons 8 "0") (cons 1 (strcat (rtos txv) dsuf)) ; Dimension Value Suffix (cons 2 "DIM-VALUE") (cons 7 (getvar "TEXTSTYLE")) (cons 10 tcp)(cons 11 tcp) (cons 39 1e-(cons 40 ts)(cons 41 txs) (cons 51 (cdr (assoc 50 sdef))) (cons 50 ara)(cons 62 1)(cons 70 0) (cond ((= flg "MC") (cons 72 1)) ((= flg "ML") (cons 72 0)) ((= flg "MR") (cons 72 2)) (T (cons 72 1))) (cons 74 2))) (entmake (list (cons 0 "ATTRIB")(cons 1 "")(cons 8 "0")(cons 2 "STR-VALUE") (cons 7 (getvar "TEXTSTYLE")) (cons 10 scp)(cons 11 scp) (cons 39 1e-(cons 40 ts)(cons 41 txs) (cons 51 (cdr (assoc 50 sdef)))(cons 50 ara) (cons 62 4)(cons 70 0)(cons 72 4))) (entmake (list (cons 0 "SEQEND"))) (entlast)) No error checking or trapping 4 Dims per side - Overall, Rh Min - LH Min - Center Balance Have Fun ! -David Edited August 10, 2015 by David Bethel Fix Z axis problems Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 10, 2015 Share Posted August 10, 2015 looks like exactly what the dragon , pardon , doctor ordered , thanx Lee , real smooth Thanks rlx, you're welcome Quote Link to comment Share on other sites More sharing options...
