Startup Autocad with two setup options
yrnomad
I've got users that work for two different departments. One using 1 unit = 1' and the other using 1 unit = 1".
So, I'd like to load a different set of Lisps at startup depending on who they are working for. I have them loading a list with the ACADDOC.lsp for the majority of their work (the 1=1" folk), but they grip when they have to switch and the routine's aren't preloaded.
Any way to do this?
Any way to do this?
i practice using autocad profile on every project we have.
for example:
Shortcut #1
"C:\Program Files\Autodesk\AutoCAD 2011\acad.exe" /p "P:\PROJECTS\PROJECT1.arg"
Shortcut #2
"C:\Program Files\Autodesk\AutoCAD 2011\acad.exe" /p "P:\PROJECTS\PROJECT2.arg"
we have more than 50 prjects here and most of them are autocad.
Thanks, I'll try the profile switch.
ReMark: The unit=inch projects use layouts and viewports, annotative scale. Where as, the unit=foot projects (electrical utility work) only draw in model space, and do straight up dimscale/text size.
