extract all coordinate and dimension from autocad drawing
raj patel
 Share
i want to extract all coordinate and dimension from AutoCAD drawing(attached file)
i am using below code they extract only circle dimension, what can i do to extract other dimension..
(vl-load-com)
(defun c:test (/ i e p1 p2 ss lst q var f fn dat dat1)
;hanhphuc 2014
(set 'var (getvar 'cmdecho ))
(setvar 'cmdecho 0)
(if (and (setq e (entsel "\nPlease select solid.. ")) (setq e (car e)) (= (cdr (assoc 0 (entget e))) "3DSOLID"))
(progn (vla-GetBoundingBox (setq obj (vlax-ename->vla-object e)) 'p1 'p2)
(mapcar ''((a b) (set a (vlax-safearray->list b))) '(p1 p2) (list p1 p2))
(command "_explode" e)
(setq i 0
ss (ssget "C" p1 p2)
lst (mapcar '(lambda(x)
(setq q nil)
(if
(= (cdr (assoc 0 (entget x))) "REGION")
(setq q (cons (LM:reg x) q))
(setq q (cons (vlax-ename->vla-object x) q))
(if
(listp q)
(LM:flatten q)
q
(vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
) ;_ end of mapcar
) ;_ end of setq
(foreach o (vl-remove-if-not ''((x) (= (vla-get-ObjectName x) "AcDbCircle")) (LM:flatten lst))
(setq dat(cons (princ (strcat "\nCIRCLE_" (itoa (setq i (1+ i))) " "
(vl-princ-to-string
(mapcar ''((x)(vlax-get o x)) '(Radius Center))
dat))
) ;_ end of foreach
(command "_.U")
(setq fn (strcat (getvar "dwgprefix") "hole dat.csv") f (open fn "w"))
; If you don't want to override file ,to append use (open fn "a") as suggested by Marko @ post#14
(foreach $
(foreach x dat
(setq dat1 (cons (vl-string-translate
(vl-list->string
(vl-remove-if ''((a) (or (= a 10) (= a 40) (= a 41))) (vl-string->list x))
) ;_ end of vl-list->string
) ;_ end of vl-string-translate
dat1
) ;_ end of cons
) ;_ end of setq
) ;_ end of foreach
(write-line $ f))
(write-line " " f)
(if f (close f))
(startapp "notepad" fn) ;
) ;_ end of progn
) ;_ end of if
(setvar 'cmdecho var)
) ;_ end of defun
;;;http://www.cadtutor.net/forum/showthread.php?35506-How-to-get-Region-coordinates/page2
;;;adopted as sub-function
(defun LM:reg (reg / RetObj)
(setq Reg (vlax-ename->vla-object reg))
(if (vlax-method-applicable-p reg 'explode)
(setq RetObj (vlax-safearray->list (vlax-variant-value (vla-explode Reg))))
(repeat (length RetObj)
(if (eq "AcDbRegion" (vla-get-ObjectName (car RetObj)))
(setq RetObj (append RetObj (vlax-safearray->list (vlax-variant-value (vla-explode (car RetObj))))))
(setq RetObj (append RetObj (list (car RetObj))))
) ;_ end of if
(setq RetObj (cdr RetObj))
) ;_ end of repeat
retobj
) ;_ end of defun
;; Flatten List - Lee Mac
;; Transforms a nested list into a non-nested list
;; http://www.lee-mac.com/flatten.html
(defun LM:flatten ( l )
(if (atom l)
(list l)
(append (LM:flatten (car l)) (if (cdr l) (LM:flatten (cdr l))))
 Share
