ColinHolloway
Issue with calling a .NET LispFunction with a Reactor
ColinHolloway
Hi All,
I have just hit a wall with some code I am working on and wondered if anyone had seen a similar situation (and found a solution).
I have written a .NET routine that I use to control which Ribbon Menu Tabs and Panels are visible based on arguments passed to the routine. This runs correctly in AutoCAD 2016 when I call it from the command line or from inside a lisp function or command. However when I call the .NET routine from a reactor it fails:
Command: System.ArgumentNullException: Value cannot be null.
Parameter name: key
  at System.Collections.Generic.Dictionary`2.FindEntry(TKey key)
  at System.Collections.Generic.Dictionary`2.TryGetValue(TKey key, TValue& value)
  at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
  at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.InvokeLisp(); error: ADS request error
EDIT: I have found that calling ANY command from a reactor fails e.g. (command "line" "0,0" "1000,1000") called by a reactor the error is:
Command: ; error: AutoCAD command rejected: "line"
Any and all thoughts greatly appreciated.
Colin
Edited by ColinHolloway
more information collected
Share this post
Link to post
Lee Mac
Yes, you cannot invoke a command from within a reactor callback function - a possible workaround is to invoke the command 'post-process' (using vla-sendcommand, for example).
Share this post
Link to post
ColinHolloway
Hi Lee and Al,
Thank you for your replies.
I have added the vla-sendcommand call to my reactor and when I use it to do something "trivial" like zoom extents it works as expected, but when I call the .NET LispFunction it still fails:
(setq activedwg (vla-get-activedocument (vlax-get-acad-object)) )
(vla-SendCommand activedwg "(ribboncontrol \"Sedgman\" \"SedgCAD Legacy\" 0)\r")
Command: (ribboncontrol "Sedgman" "SedgCAD Legacy" 0)
Parameter name: key
Command:
Note: If I paste (ribboncontrol "Sedgman" "SedgCAD Legacy" 0) directly to the command line it works as expected.
Is there an issue with calling a .NET LispFunction inside a reactor callback function even when using vla-sendcommand?
Maybe I need a completely fresh look at this problem...
What I am attempting to write is contextual ribbon menu control based on a variable set in the current drawing. The .NET Lisp Function I have written shows or hides a ribbon panel based on the arguments passed to it.
On drawing open I set a variable based on the folder the drawing was opened from and display the relevant panels in the ribbon menu. This works on startup, but I was hoping to be able to make the same change (if necessary) when switching drawing tabs (because each drawing can be opened from a different source). I have looked at contextual ribbon tabs in the CUI but that doesn't solve the issue of showing/hiding panels based on a local variable. Using a reactor to call my .NET routine seemed like the correct way to go, but I feel I am pushing the limits of what can be done. Thoughts?
Thanks again,
Colin
EDIT: I am developing this code in AutoCAD 2016 and on a hunch I fired up an AutoCAD 2014 machine and tried to run the code above... it worked perfectly. I was even able to remove the vla-SendCommand and call the .NET LispFunction (with required arguments) directly!!! What has changed in the calling of commands and .NET functions between 2014 and 2016?
New Information
Share this post
Link to post
