3drookie
Loft command question
3drookie
When using loft,if Mode is Solid, what determines the wall thickness of the resulting solid?
Related: I am trying to work around the error of curved objects/surfaces intersecting with themselves when they are thickened.
Thanks in advance
Share this post
Link to post
ReMark
Normally it would be the distance between the lofted profiles but without seeing your drawing I can't give you a definitive answer.
Attach a copy of the drawing to your next post. Someone here will take a look at it and perhaps have a solution to your problem.
Edited by ReMark
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
