WPerciful Posted December 23, 2015 Share Posted December 23, 2015 I've working on an A1 border that matches our ANSI D border. We use the following text heights: 1/16" 3/32" --- Our standard text height for most work 1/8" 5/32" 1/4" Does anyone know what the BSI or ISO standard text heights for an A1 border would be? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 23, 2015 Share Posted December 23, 2015 I don't believe that the size of the paper is a determining factor. I would stay away from 1/16" except for maybe plot stamps, or something like copyright text that really has nothing to do with the project. It is too small when reduced. Although, I do see a value in having a size smaller than 3/32". I've seen it as small as 9/128". My office uses 5/64" for plan text. Our plans can get quite congested and 3/32" is just too big, too often. Also, I don't see any reason for the 5/32". What do you use it for? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 24, 2015 Share Posted December 24, 2015 An A1 is metric size but your text is in inches ? Do you mean 36x24" sheet size ? A1 is 33.11x23.38" To confuse a bit more we plot A3 majority of time but the plans are drawn on a A1 sheet. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 24, 2015 Share Posted December 24, 2015 Good catch BIGAL. Quote Link to comment Share on other sites More sharing options...
WPerciful Posted December 25, 2015 Author Share Posted December 25, 2015 We’re in the process of developing our drafting and design standards. In the past we’ve relied entirely on the EPC/Vendor to use their own drafting standards. We have a 22”x34” ANSI D border which is being used for our US work. I’ve attached it. I’ve been tasked with making a BSI/ISO version of this border. It’s to be an A1 sized border. The standard practice being to work and PDF in full size but the user typically prints the PDF down to an A3 (or 11”x17” in the US). We use five different text heights on our US work. I’ve listed them below. I’m not sure what the standard mm text height is for BSI or ISO work. I’d like to know what the standard text heights would be in BSI work and what the margins would be. 1/16" --- For fine detailing annotation 3/32" --- Our standard text height for most work 1/8" --- Sub-titles 5/32" --- Titles 1/4" --- Drawing titles Thank you for all of the help, and happy holidays. Border.dwg Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 25, 2015 Share Posted December 25, 2015 Results from a google search (BSI standard text heights) that took all of 23 seconds, including eyeball reading time. Perhaps there is more, if you would like to take over the research end. This is from the Imperial College, London: 4.3 Text styles The text shall be standardised to STANDARD Arial. All drawings are to have a standard text heights of 2.5mm, 3.5mm, 5.0mm and 7.0mm and a width no greater than 1 at a scale of 1:1. For example a drawing drawn at 1:100 would have a text height (in Model Space) of 250mm, and the height of the text in Paper Space would be 2.5mm. Blocks and Title blocks should be left in the text style they were made in and not changed to Standard Arial. Hopefully this will help prevent you from having to post the same question a third time without any mention of your own research attempts. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 25, 2015 Share Posted December 25, 2015 Good one Dana only suggestion is to use Iso3098B instead of Arial this is a thin pen text style rather than Arial which has a thickness. Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 25, 2015 Share Posted December 25, 2015 Good one Dana only suggestion is to use Iso3098B instead of Arial this is a thin pen text style rather than Arial which has a thickness.Yep, and the point is, other than height, (and even that will bend), there are no real standards. Just make it clear, and simple, and not too tiny. Quote Link to comment Share on other sites More sharing options...
WPerciful Posted December 26, 2015 Author Share Posted December 26, 2015 Dana, Industry practices are not always in line with a given standard. The ISA standard depictions for piping and instrumentation diagrams are more of a guideline then a standard practice. I was looking for opinions as to best practice from CAD Managers who work with/in BSI and or ISO. For example the standard border for P&ID’s is 22”x34” ANSI D however the industry commonly uses an ARCH D any CAD Manager in a US based petrochemical design firm would know that. The industry is moving to the ARCH D border to increase drawing area. Hopefully in the office you’re more apt to inquire and help then you are to quip. Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 26, 2015 Share Posted December 26, 2015 Dana, Industry practices are not always in line with a given standard. The ISA standard depictions for piping and instrumentation diagrams are more of a guideline then a standard practice. I was looking for opinions as to best practice from CAD Managers who work with/in BSI and or ISO. For example the standard border for P&ID’s is 22”x34” ANSI D however the industry commonly uses an ARCH D any CAD Manager in a US based petrochemical design firm would know that. The industry is moving to the ARCH D border to increase drawing area. Hopefully in the office you’re more apt to inquire and help then you are to quip. You repeated the same question without responding to anyone at all, in any way, which was this... I’m not sure what the standard mm text height is for BSI or ISO work. I’d like to know what the standard text heights would be in BSI work and what the margins would be. I am not quipping, I am purposefully admonishing. In my office questions are asked, answers discussed and solutions found. We don't simply ignore people, and then repeat, word for word, the same question, nor do we do in in a professional forum. My participation has ended. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 26, 2015 Share Posted December 26, 2015 Does anyone know what the BSI or ISO standard text heights for an A1 border would be? Industry practices are not always in line with a given standard. So, what is the question? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 26, 2015 Share Posted December 26, 2015 For us in AUS https://www.saiglobal.com/PDFTemp/Previews/OSH/As/as1000/1100/1100101.pdf Find the standard for where your trying to prepare drawings and see how close you can get. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted December 28, 2015 Share Posted December 28, 2015 http://www.roymech.co.uk/Useful_Tables/Drawing/Lettering.html Quote Link to comment Share on other sites More sharing options...
WPerciful Posted December 28, 2015 Author Share Posted December 28, 2015 BIGAL, Thank you for the link. Australian standards are a plus, as it's for an Australian based company. Quote Link to comment Share on other sites More sharing options...
WPerciful Posted December 28, 2015 Author Share Posted December 28, 2015 stevsmith, Thank you sir. This will help me to reach a conscious Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 28, 2015 Share Posted December 28, 2015 Wperciful remember a foot is not 304 mm you should use 300mm etc a lot of stuff is a mix of imperial and metric. I would draw it all starting with a metric template. What is it your designing civil mechanical architectural ? Quote Link to comment Share on other sites More sharing options...
WPerciful Posted December 28, 2015 Author Share Posted December 28, 2015 BIGAL, The borders will be used for all disciplines: piping,mechanical, electrical/instrumentation, civil, structural and architectural. At present we only have/use imperial units. For this first round of metric borders (ormixed metric) perhaps the scope should be limited to drawings that are not toscale. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 29, 2015 Share Posted December 29, 2015 Just set up your sheet to true A1 size 841 x 594mm less margins and you can print on a 36x24 no probs for checking. See my very early post. Quote Link to comment Share on other sites More sharing options...
Organic Posted January 2, 2016 Share Posted January 2, 2016 For us in AUS https://www.saiglobal.com/PDFTemp/Previews/OSH/As/as1000/1100/1100101.pdf Find the standard for where your trying to prepare drawings and see how close you can get. That standard is 24 years old now and from memory barely mentions CAD. Besides from the occasional state government body who contractually note that drawings are to be prepared in accordance with the standard I have rarely seen it requested (and as such used to the letter, particularly given it is severely lacking in some areas in my opinion). It does give someone with little experience of drafting a starting point though. Australian standards are a plus, as it's for an Australian based company. The borders will be used for all disciplines: piping,mechanical, electrical/instrumentation, civil, structural and architectural. If they are a multidisciplinary firm like that then perhaps they might already have a template they use which you could start with? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 2, 2016 Share Posted January 2, 2016 That standard is 24 years old now and from memory barely mentions CAD. That's because it is not a CAD standard. Quote Link to comment Share on other sites More sharing options...
