Jmclachlan
Dynamic Block with different x,y,z scale?
Jmclachlan
As a result of multiple updates of AutoCAD software and addition of 12D software I have lost the ability to block replace a block with different x,y,z scales with a dynamic block and have the dynamic block retain its function. Is there a way for the dynamic block to work with different x,y,z scales?
Share this post
Link to post
steven-g
Nope, and with some geometry it also becomes impossible to explode some blocks.
Share this post
Link to post
Jmclachlan
Thank for the timely response. I will try to find a different way to approach the problem without a dynamic block.
Share this post
Link to post
steven-g
The block should scale with no problems, it will just lose it's dynamic ability when using diffrent scales for X,Y and Z, so you can still use it with it's dynamic functions at equal scale values, then change the scale to suit what you need
Share this post
Link to post
