CesarA
Changing a hatch pattern scale, from a solid hatch
CesarA
I've read the documentation in the autocad site and to change from solid to other kind of hatch you must mess up 2 dxf codes. 70 is 1 or 0 accordingly to solid or not. 2 is the hatch patern indeed. and finally 41 is the dxf for the scale of the pattern.
So I tried to do the following:
(defun c:efg ( / trama solido e o s x texto tipodepeca z y)
   (if (setq s (ssget "_:L" '((0 . "HATCH"))))
       (repeat (setq i (sslength s))
           (setq e (ssname s (setq i (1- i)))
                 x (entget e)
                 trama (cdr (assoc 2 x))
			  solido (cdr (assoc 70 x))
		(setq z (entmod (subst 0 solido x))) ;;;; change the dxf 70 from 1 (solid) to 0 (not solid)
			(if (= trama "SOLID")
					(setq y (entmod (subst '(8 . "est.Trama") (assoc 8 x) z))) ;;;; Changes layer
					(setq w (entmod (subst '(2 . "AR-CONC") (assoc 2 x) y))) ;;;;Changes type of hatch
					(entmod (subst '(41 . 0.01) (assoc 41 x) w)) ;;;;Changes pattern scale (or shouldn't?)
Basically I change the dxf 70 from 1 to 0 (so that I can enable a not-solid hatch) and then change the dxf 2 to other pattern.
The problem is that everything works allright, but the scale pattern doesnt change. (the layer and the hatch name are correct).
Does this have to do with the order in which I modify the settings?
Edited by CesarA
Share this post
Link to post
CesarA
By the way I'm also trying to delete some hatches using
(ssdel x s)
which translantes to (ssdel ename sslist) or something similar. I think the command is correctly written, but he doesnt delete the hatch regardless.
Edit: solution for removal:
(command "erase" e "")
The pattern scale problem persists somehow, any hint?
Edited by CesarA
Share this post
Link to post
Lee Mac
ssdel will remove an entity from a selection set; use entdel to set the erase flag for an entity in the drawing database.
Share this post
Link to post
CesarA
damn Lee mac, when I've seen you replied I hoped you had a hint on the pattern scale, the deletion is taken care of, the first problem persists tough..
Share this post
Link to post
Lee Mac
Excuse me?
Share this post
Link to post
CesarA
hmm.. yes? I didn't mean "damn you lee mac", but rather "damn my luck, lee mac" if that's what is bothering you :) I'm more than happy with your help
Share this post
Link to post
Lee Mac
I don't believe that you can modify a HATCH entity in this way in order for the pattern to display correctly, as the DXF data for a pattern filled hatch contains separate pattern data which is not present for a solid hatch. Furthermore, the pattern name and pattern type ActiveX properties are read-only, which would indicate that such objects cannot be tranformed into each other.
I believe you would instead need to rebuild the HATCH to include this additional data - for this, I would strongly recommend using the ActiveX(COM) methods offered by Visual LISP, as entmake'ing a HATCH entity can be troublesome.
Here are some examples of how to create a hatch using Visual LISP:
Isometric Hatched Triangle
Offset & Hatch Polylines
Solid Hatch in Visual LISP
Share this post
Link to post
CesarA
You are probably right.. anyways I checked a dxf list of a hatch and something strange happens
((-1 . ) (0 . "HATCH") (330 . ) (5 . "5F4761") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "est.Trama") (100 . "AcDbHatch") (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 . "AR-CONC") (70 . 0) (71 . 0) (91 . 1) (92 . 3) (72 . 0) (73 . 1) (93 . 4) (10 3891.11 -3551.41 0.0) (10 3890.86 -3551.41 0.0) (10 3890.86 -3551.11 0.0) (10 3891.11 -3551.11 0.0) (97 . 0) (75 . 0) (76 . 1) (52 . 0.0) (41 . 0.01) (77 . 0) (78 . 13) (53 . 0.872665) (43 . 0.0) (44 . 0.0) (45 . 0.071726) (46 . -0.00627521) (79 . 2) (49 . 0.0075) (49 . -0.0825) (53 . 6.19592) (43 . 0.0) (44 . 0.0) (45 . -0.0138751) (46 . 0.0752192) (79 . 2) (49 . 0.006) (49 . -0.066) (53 . 1.75321) (43 . 0.00597717) (44 . -0.000522934) (45 . 0.0578509) (46 . 0.068944) (79 . 2) (49 . 0.00637402) (49 . -0.0701142) (53 . 0.806066) (43 . 0.0) (44 . 0.02) (45 . 0.106724) (46 . -0.0165519) (79 . 2) (49 . 0.01125) (49 . -0.12375) (53 . 1.68661) (43 . 0.00889367) (44 . 0.0186207) (45 . 0.0934662) (46 . 0.0974119) (79 . 2) (49 . 0.00956103) (49 . -0.105171) (53 . 6.12932) (43 . 0.0) (44 . 0.02) (45 . 0.0934662) (46 . 0.0974119) (79 . 2) (49 . 0.009) (49 . -0.099) (53 . 0.366519) (43 . 0.01) (44 . 0.015) (45 . 0.0596907) (46 . -0.0402619) (79 . 2) (49 . 0.0075) (49 . -0.0825) (53 . 5.68977) (43 . 0.01) (44 . 0.015) (45 . 0.0243315) (46 . 0.072515) (79 . 2) (49 . 0.006) (49 . -0.066) (53 . 1.24706) (43 . 0.0149742) (44 . 0.0116448 ) (45 . 0.0840222) (46 . 0.0322531) (79 . 2) (49 . 0.00637402) (49 . -0.0701142) (53 . 0.654498 ) (43 . 0.0) (44 . 0.0) (45 . 0.00121599) (46 . 0.0332894) (79 . 6) (49 . 0.0) (49 . -0.0652) (49 . 0.0) (49 . -0.067) (49 . 0.0) (49 . -0.06625) (53 . 0.1309) (43 . 0.0) (44 . 0.0) (45 . 0.026307) (46 . 0.0394412) (79 . 6) (49 . 0.0) (49 . -0.0382) (49 . 0.0) (49 . -0.0637) (49 . 0.0) (49 . -0.02525) (53 . 5.71595) (43 . -0.0223) (44 . 0.0) (45 . 0.0533822) (46 . -0.00225549) (79 . 6) (49 . 0.0) (49 . -0.025) (49 . 0.0) (49 . -0.078 ) (49 . 0.0) (49 . -0.1035) (53 . 5.54142) (43 . -0.0323) (44 . 0.0) (45 . 0.0583186) (46 . 0.0100105) (79 . 6) (49 . 0.0) (49 . -0.0325) (49 . 0.0) (49 . -0.0518 ) (49 . 0.0) (49 . -0.0735) (98 . 0))
A lot of the codes repeat themselves.. shouldn't it be one code group for each parameter? Does anyone knows why this happens?
Share this post
Link to post
Lee Mac
There will be a set of 'pattern' DXF groups for each edge definition for the HATCH entity, so yes, the DXF groups will be repeated (this is similar to how DXF groups 10, 40, 41, 42 & 91 are repeated for each vertex of an LWPOLYLINE).
Share this post
Link to post
CesarA
Hmm this is interesting, this means i can probably create a similar list beyond the identity and coordinates of the hatch, and that way I'd probably have exactly what I want. Thanks Lee
Share this post
Link to post
CesarA
This was so easy...
(vl-load-com)
(defun c:efg ( / trama e o s x z y w obj patternName)
                 x (entget e)
			  obj (vlax-ename->vla-object e)
			  patternName (vla-get-patternName obj)
		    (prin1 "allright till here")
			(vla-setpattern obj acHatchPatternTypePreDefined "AR-CONC" )
			(vla-put-PatternScale obj 0.01)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
