hoptrinh Posted January 19, 2016 Share Posted January 19, 2016 Dear CAD Experts! I'm having a problem here with AutocadLT 2016. Previously, I've created this customization file to be able to use layer from drop down menu. It works perfectly and seems to be compatible with other versions from 2012 onwards until I meet this "LT guy" 2016! The thing is after importing the Layers.cuix file the Layer tab would show up on the menu bar BUT when I start to pick up the layer from the menu, AutocadLT keeps running the previous command and the layer doesn't appear in layer manager or in the drawing. Could you please let me know what is the problem and how to fix it? Here is the code that I'm using to create the layer ^C^C^P(command "_-layer" "_make" "A-_ANOTREVN_E-" "_color" "1" "" "_ltype" "continuous" "" "_lweight" "default" "" "") ^P I've also attached the Layers.cuix file for your preview. Many thanks and many kisses! Cheers, Hop Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 19, 2016 Share Posted January 19, 2016 Your problem is that is LISP and LT doesn't support LISP. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted January 19, 2016 Share Posted January 19, 2016 You'll have to do it with a macro instead. ^C^C._layer;_m;"A-_ANOTREVN_E-";_c;1;;_ltype;"continuous";;_lw;0.0;;; Quote Link to comment Share on other sites More sharing options...
hoptrinh Posted January 20, 2016 Author Share Posted January 20, 2016 Thanks a lottt rkmcswain!!! You save my life! It works perfectly now! xxx Quote Link to comment Share on other sites More sharing options...
