KBGROSSRA Posted January 28, 2016 Share Posted January 28, 2016 Somehow a drawing I thought was in 2D had numerous lines and objects that were 3D with various Z axis points. Can't get everything back to Z=0 using flatten command. Setting each item to Z=0 moves them to some other part of the drawing. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 28, 2016 Share Posted January 28, 2016 Please post the offending file. Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 28, 2016 Author Share Posted January 28, 2016 This is my first attempt on CADTutor, so hope it works. It is a 5MB file, and the limit seems to me 1MB. Even deleting many parts of the sections, it is still at 4MB+. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 28, 2016 Share Posted January 28, 2016 That is huge. Maybe you can strip it down to just a small portion that exhibits the behavior. We don't really need the entire file, just part of it to illustrate what you are talking about. Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 28, 2016 Author Share Posted January 28, 2016 Yes, we have some intrinsic issue with our files. When we start a new drawing, we usually use a similar one from a previous project and even without linework, they are huge. We used to have a command in earlier versions of ACAD that was labeled "layer filter delete" that seemed to break the connections to old drawings that we haven't bee able to recreate in our newer versions. We used to have someone who was very knowledgeable in ACAD then, but not now. Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 28, 2016 Author Share Posted January 28, 2016 OK, copied out one part, put it in new drawing file, purged and audited, and got it under 1 MB. Have a go at it. Thanks, 450 Cambridge St_SECTION PARTIAL FILE.dwg Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 28, 2016 Share Posted January 28, 2016 I don't see an easy solution. Maybe someone else will come along with something useful. Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 28, 2016 Author Share Posted January 28, 2016 Thanks for trying. Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 28, 2016 Share Posted January 28, 2016 In the attached is a polyline that has had the layer changed too "offender" I added a line pointing too it, it is this one single item that is stopping the flatten command from working as expected. There are also lots of items that have a thickness, some of them inside blocks. 450 Cambridge St_SECTION PARTIAL FILE.dwg Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 28, 2016 Author Share Posted January 28, 2016 I removed that object and tried the flatten command again, but nothing changed. Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 28, 2016 Share Posted January 28, 2016 In this one everything is flattened and thickness removed. I exploded all the blocks with thickened objects. 450 Cambridge St_SECTION PARTIAL FILE.dwg Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 28, 2016 Author Share Posted January 28, 2016 is there some way to isolate all the blocks with thickened objects so they can be exploded without exploding everything? Thanks, Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 29, 2016 Share Posted January 29, 2016 We use a more specific approach making known objects to z=0. Flatten tried to make Civ3D cogo points to z=0 ? they are huge You need to look at the dwg carefully it sounds to me like you have blocks that are say dwg's inside your dwg, as a test do purge and saveas something else. We have various purge routines that only do say certain clean up PURGE Layers road* etc. We have block library rather than all blocks in the template. ; changes all level to zero (vl-load-com) (defun dxf(code elist) (cdr (assoc code elist)) ) (defun circ0 (/ g n lg e os ns el nl) (princ "\nChanging CIRCLES: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "CIRCLE" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq os (assoc 10 e)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq e (subst ns os e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun line0 (/ g n lg e os ns of nf el nl) (princ "\nChanging LINES: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "LINE" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq os (assoc 10 e)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq e (subst ns os e)) (setq of (assoc 11 e)) (setq nf (list(car of)(cadr of)(caddr of) 0.0)) (setq e (subst nf of e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun arc0 (/ g n lg e os ns el nl) (princ "\nChanging ARCS: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "ARC" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq os (assoc 10 e)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq e (subst ns os e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun sol0 (/ g n lg e o1 n1 o2 n2 o3 n3 o4 n4 el nl) (princ "\nChanging SOLIDS:" ) (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "SOLID" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq o1 (assoc 10 e)) (setq n1 (list(car o1)(cadr o1)(caddr o1) 0.0)) (setq e (subst n1 o1 e)) (setq o2 (assoc 11 e)) (setq n2 (list(car o2)(cadr o2)(caddr o2) 0.0)) (setq e (subst n2 o2 e)) (setq o3 (assoc 12 e)) (setq n3 (list(car o3)(cadr o3)(caddr o3) 0.0)) (setq e (subst n3 o3 e)) (setq o4 (assoc 13 e)) (setq n4 (list(car o4)(cadr o4)(caddr o4) 0.0)) (setq e (subst n4 o4 e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun text0 (/ g n lg e os ns of nf el nl) (princ "\nChanging TEXT: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "TEXT" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq os (assoc 10 e)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq e (subst ns os e)) (setq of (assoc 11 e)) (setq nf (list(car of)(cadr of)(caddr of) 0.0)) (setq e (subst nf of e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun pt0 (/ g n lg e os el nl) (princ "\nChanging POINTS: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "POINT" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq os (assoc 10 e)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq e (subst ns os e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun dim0 (/ g n lg e o1 n1 o2 n2 o3 n3 o4 n4 o5 n5 o6 n6 o7 n7 el nl) (princ "\nChanging DIMS: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "DIMENSION" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq o1 (assoc 10 e)) (setq n1 (list(car o1)(cadr o1)(caddr o1) 0.0)) (setq e (subst n1 o1 e)) (setq o2 (assoc 11 e)) (setq n2 (list(car o2)(cadr o2)(caddr o2) 0.0)) (setq e (subst n2 o2 e)) (setq o3 (assoc 12 e)) (setq n3 (list(car o3)(cadr o3)(caddr o3) 0.0)) (setq e (subst n3 o3 e)) (setq o4 (assoc 13 e)) (setq n4 (list(car o4)(cadr o4)(caddr o4) 0.0)) (setq e (subst n4 o4 e)) (setq o5 (assoc 14 e)) (setq n5 (list(car o5)(cadr o5)(caddr o5) 0.0)) (setq e (subst n5 o5 e)) (setq o6 (assoc 15 e)) (setq n6 (list(car o6)(cadr o6)(caddr o6) 0.0)) (setq e (subst n6 o6 e)) (setq o7 (assoc 16 e)) (setq n7 (list(car o7)(cadr o7)(caddr o7) 0.0)) (setq e (subst n7 o7 e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun pline0 (/ g n lg e os ns el nl ed en) (princ "\nChanging PLINES and DONUTS: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "POLYLINE" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq os (assoc 10 e)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq e (subst ns os e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) (SETQ en (DXF -1 e)) (while (and (setq en (entnext en)) (SETQ ED (ENTGET EN)) (/= "SEQEND" (dxf 0 ed)) ) (progn (setq os (assoc 10 ed)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq ed (subst ns os ed)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod ed) ) ) (entupd en) ) ) (setq n (1+ n)) ) )) ) (defun lwpline0 ( / ss num x) (setq ss (ssget "P")) (setq num (sslength ss)) (setq x num) (repeat num (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (if (= (vla-get-objectname obj) "AcDbPolyline") (vla-put-elevation obj 0.0) ) ) ) (defun ins0 (/ g n lg e os ns el nl) (princ "\nChanging BLOCK INSERTS: ") (setq g (ssget "P")) (if g (progn (setq n 0 lg (sslength g)) (while (< n lg) (if (= "INSERT" (cdr (assoc 0 (setq e (entget (ssname g n)))))) (progn (setq os (assoc 10 e)) (setq ns (list(car os)(cadr os)(caddr os) 0.0)) (setq e (subst ns os e)) (setq el (assoc 38 e)) (setq nl (cons 38 0.0)) (setq e (subst nl el e)) (entmod e) ) ) (setq n (1+ n)) ) )) ) (defun c:zero () (setq g (ssget)) (circ0) (line0) (arc0) (sol0) (text0) (pt0) (dim0) (pline0) (lwpline0) (ins0) (princ) ) Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 29, 2016 Author Share Posted January 29, 2016 Steven-g, what is the process you go through to achieve this? I explode the blocks with thickened objects, run flatten command and nothing changes. Could I send you more elevations? I'm afraid my ACAD skills are too basic. Thank you. Quote Link to comment Share on other sites More sharing options...
KBGROSSRA Posted January 29, 2016 Author Share Posted January 29, 2016 Thanks BigAl, I posted one of my drawings which you can look at. The blocks inside the drawing aren't that complex. It seems to have more with inherited layer filters that are hidden. Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 29, 2016 Share Posted January 29, 2016 Flatten doesn't work for thickness. To do that I used the qselect command to find all lines with a thicness not equal to zero, and changed it to zero in the properties palette, then the same again for polylines. For finding the correct blocks to explode I turned the view to front view and the objects not at zero should show up. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 29, 2016 Share Posted January 29, 2016 KBGROSSRA dwg is where ? Thickness is probably a variable that started with Autocad and is a poor mans 3D you can have both thickness and a Z or elevation on a object, rather than flatten the block objects it be to only set ELEV to zero. This is two lines Select objects: LINE Layer: "0" Space: Model space Thickness = 2400.000 Handle = 606d from point, X= 6685.930 Y= 2745.541 Z= 5000.000 to point, X= 9342.205 Y= 2501.736 Z= 5000.000 Length = 2667.440, Angle in XY Plane = 354d45'21" Delta X = 2656.275, Delta Y = -243.805, Delta Z = 0.000 LINE Layer: "0" Space: Model space Thickness = 2400.000 Handle = 606b from point, X= 6685.930 Y= 3161.445 Z= 0.000 to point, X= 9342.205 Y= 2917.639 Z= 0.000 Length = 2667.440, Angle in XY Plane = 354d45'21" Delta X = 2656.275, Delta Y = -243.805, Delta Z = 0.000 Quote Link to comment Share on other sites More sharing options...
