kiranvarghese1
I cannot print text inside my autocad print out everything else is coming
kiranvarghese1
Hi guys am new to autocad when i tried to take a print out the text inside there is not showing but everything else like lines and dimensions are there pls help me
Share this post
Link to post
nod684
can you upload the part of the file if possible?
Share this post
Link to post
nod684
zoom extent and delete the polyline (rectangle) that you see and zoom extent again.
Share this post
Link to post
kiranvarghese1
Nod684 thanks for your reply can you please provide me your email id am new to autocad
Share this post
Link to post
nod684
just post here is you need help in autocad.
guys here are very much willing to help you :)
Share this post
Link to post
kiranvarghese1
one more doubt i have that how to create an polygon isometrically
Share this post
Link to post
nod684
That should be another thread.
but anyway, you might try looking at LeeMac's IsoPoly lisp
Edited by nod684
Share this post
Link to post
kiranvarghese1
i tried leemacs command but its not working for me
Share this post
Link to post
nod684
what error did you get?
I've been using that lisp for a long time now without any problems.
Share this post
Link to post
kiranvarghese1
i upoaded the lisp file
but even after that the hexagon is not coming is isometric view
Share this post
Link to post
nod684
make sure you are in Isometric mode (SNAPSTYL set to 1)
load Lee's Isopoly and type the command. Follow the on-screen instruction on your status bar below and it should work fine
Share this post
Link to post
kiranvarghese1
Command: isostyl
Unknown command "ISOSTYL". Press F1 for help.
Command: snapstyl
Enter new value for SNAPSTYL : 1
Command: appload
IsoPolyV1-0.lsp successfully loaded.
Command:
Command:
Command:
Command:
Command: _polygon Enter number of sides :
Specify center of polygon or [Edge]:
Enter an option [inscribed in circle/Circumscribed about circle] : C
Specify radius of circle: *Cancel*
i did the same what you told but the hexagon which i drawn remains still in one plane
Share this post
Link to post
nod684
you loaded the lisp but did not run it. you are still using Autocad's native polygon command.
load the lisp IsoPoly and type ISOPOLY on the command line.
Share this post
Link to post
kiranvarghese1
thanks a lot for your quick reply it worked :D
Share this post
Link to post
nod684
you're welcome.
credit goes to Lee Mac :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
