steelcityj20010
Is there a way to remove layers in bulk?
steelcityj20010
I have a series of drawings that I am now in charge off and three or more people have worked on it. I have changed all of the layers on the drawing to my layers. but there is 50 or more layers from other people editing these drawings. is there any way to remove the layers at once or can I only remove them one at a time with LALDEL? I appreciate any help.
Share this post
Link to post
tzframpton
PURGE command.
Share this post
Link to post
danellis
You can delete multiple layers through LAYDEL
Go into the command then type N for NAME. This will open a dialogue box with a list of layers. These day be selected using the normal Windows selection methods (shift at start and end of a selection set; control to add-remove individual items)
Usual warning about being VERY CAREFUL when using laydel apply!!
dJE
Share this post
Link to post
RobDraw
It can also be done through the layer manager. This method will not delete layers that are in use, similar to purge.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
