russ1234 Posted March 14, 2016 Share Posted March 14, 2016 hi all hopefully you can help. I'm running autocad 2015 and when i go from 2d into 3d the mouse pointer no longer lines up with the cross-hairs. any help would be a great help as this is making life very frustrating. many thanks in advance Russell Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2016 Share Posted March 14, 2016 What are you doing when your mouse pointer is visible on screen? Are you in the drawing portion of your workspace or hovering over the Ribbon (or a palette)? Why does your profile say you are using AutoCAD 2016? Quote Link to comment Share on other sites More sharing options...
russ1234 Posted March 14, 2016 Author Share Posted March 14, 2016 thanks for getting back to me. i am working in the drawing window. to explain, the cross-hair will be on one line and the highlighted selection will be about 1-2cm higher (same for when i go to the ribbon the pointer will be in the ribbon but the cross-hair will be allot lower) this only happens once im in 3d view Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2016 Share Posted March 14, 2016 It isn't anything I've ever noticed and I have been using 2015 since it first was released. My guess would be either it is a problem with your mouse or some kind of glitch with your graphics card. Did you try swapping out the mouse? What mouse is being used? Maybe it is a driver issue. When did you first notice this anomaly? BTW...did you install the service pack for 2015? Quote Link to comment Share on other sites More sharing options...
TheCADnoob Posted March 14, 2016 Share Posted March 14, 2016 is the behavior replicated in all views like wireframe, conceptual, hidden, etc.? Quote Link to comment Share on other sites More sharing options...
Tyke Posted March 14, 2016 Share Posted March 14, 2016 I had just this problem on one of the CAD stations in the office. I replaced the graphics card and it went away. First try installing the latest version of your graphic card'd driver. If your computer has an on-board graphics card you could have a problem. Quote Link to comment Share on other sites More sharing options...
