NIEKO Posted April 6, 2016 Share Posted April 6, 2016 I AM USING AUTOCAD 2013 AND I HAVE CUSTOMIZED MY MAIN "ACAD.CUI" FILE EXTENSIVELY. MY FRIEND USES ACAD 2016. CAN I COPY AND REPLACE HIS "ACAD.CUI" FILE WITH MINE SO HE CAN ALSO BENEFIT FROM MY CUSTOMIZATION THX nieko Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 7, 2016 Share Posted April 7, 2016 Some commands may disappear between the versions example ddptype. Otherwise should work I would rename and use menuload. I have for to many years stayed away from customising acad.mnu for that very reason when upgrading what does it affect. Maybe have a look at pulling all your customisation out into Partial menu's, pretty simple if you have just added new pull downs or custom toolbars. I only edit the partials so very easy to swap changes menuunload-menuload. Ps all caps implys we are hard of hearing. Quote Link to comment Share on other sites More sharing options...
NIEKO Posted April 7, 2016 Author Share Posted April 7, 2016 BIGAL Thanks I will follow that route nieko Quote Link to comment Share on other sites More sharing options...
dkeran Posted April 8, 2016 Share Posted April 8, 2016 I don't change the main "ACAD.CUI" file. I create a new one then change the main customisation file from options. I wouldn't like for something to go wrong and have no fall back file. Quote Link to comment Share on other sites More sharing options...
