Ski_Me Posted May 2, 2016 Share Posted May 2, 2016 I got this block I use for my wiring riser. Most of the time the devices are on the left side of the panel but some times if the job is big enough I will draw device on both sides of the panel. Problem is I need the line that is coming from the block to be on the other side. I did a rotation action on the line but it doesn't connect on the other side as you can see. I tried to figure something out in the block editor but couldn't get it to work. I thought I could detach from one side of the block and move the line to the other side of the block. Anybody have any ideas? RISERBLOCKS.dwg Quote Link to comment Share on other sites More sharing options...
