Lisp to set plot up
Baber62
Hi Guys I came across the following routine, from https://forums.autodesk.com/t5/forums/forumtopicprintpage/board-id/130/message-id/336228/print-single-message/false/page/2
However, when I tried it it gives me an error message ; error: no function definition: LM:ODBX
How can I get this to work and also change the default size to A1 rather than A2.
(defun c:RV ( / )
   (LM:ODBX
       (function
           (lambda ( doc )
	(princ (strcat "\nOpening file : "(vla-get-name doc)))
	(vlax-for lay (vla-get-layouts doc)
		; (if ( = "Model" (vla-get-name lay))
			; (progn
			(setq PaperSize "ISO_A2_(594.00_x_420.00_MM)");-----default paper size
			(princ "\nSearching for Title Block")
			(vlax-for blk (vla-get-blocks doc)
			(cond
				(( = (vla-get-name blk) "Title_A4") (setq PaperSize "ISO_A4_(297.00_x_210.00_MM)"))
				(( = (vla-get-name blk) "A3 Drawing Sheet") (setq PaperSize "ISO_A3_(420.00_x_297.00_MM)"))
				(( = (vla-get-name blk) "Title_A2") (setq PaperSize "ISO_A2_(594.00_x_420.00_MM)"))
				(( = (vla-get-name blk) "Title_A1") (setq PaperSize "ISO_A1_(841.00_x_594.00_MM)"))
			);cond
			);vlax-for blocks
			(princ (strcat "\nPaper Size Assigned : " PaperSize))
			; );progn
		; );if model space
		(vla-put-ConfigName lay "DWG To PDF.pc3")	;set the plotter
		(vla-put-CanonicalMediaName lay PaperSize)		;set the paper size--->
		(vla-put-PlotType lay "1")			;plot area extens
		(vla-put-CenterPlot lay "1")			;center plot
		(vla-put-PaperUnits lay "1")			;set units to mm
		(vla-put-PlotWithLineweights lay "0")		;turn off lineweights
		(vla-put-PlotWithPlotStyles lay "1")		;turn on plot styles
		(vla-put-StandardScale lay "0")			;fit to paper
		(vla-put-stylesheet lay "Grayscale.ctb")	;set  the CTB
		(princ (strcat "\nPlot settings done for : "(vla-get-name lay)))
	);vlax-for
	(princ "\n--------------------------------------------------")
       nil t
);defun
Re: change default paper size. Wouldn't you just substitute "ISO_A1_(841.00_x_594.00_MM)") for "ISO_A2_(594.00_x_420.00_MM)") where it says (setq PaperSize...default paper size? Can't help you with the first question. Sorry.
In general, if you see a function that starts with LM: it will have been created by Lee Mac because that is his signature he puts on nearly all functions (you can also bet that it will be an awesome function because he is the master of all things LISP haha). That function can be found on his website http://www.lee-mac.com/odbxbase.html.
Haha! Thanks broncos :thumbsup:
My $0.05 went a slightly different way just have a pull down menu with the various plot sizes and destination printer hard coded rather than select. Pick option 20 sheets come out etc.
  • 5 years later...
@Lee Mac
@BIGAL
I'm using this great code.
I wonder if it is possible to change all DWG files including subfolders.
Best regards,
(defun c:RV ( / )
    (LM:ODBX
        (function
            (lambda ( doc )
                (setq PaperSize "ISO_A3_(297.00_x_420.00_MM)");-----default paper size for Modelspace
                (princ "\nSearching in Model space for Title Block")
                (cond
                    (( = (vla-get-name blk) "A4 Drawing Sheet") (setq PaperSize "ISO_A4_(210.00_x_297.00_MM)")(vla-put-PlotRotation lay "1"))
                    (( = (vla-get-name blk) "A3 Drawing Sheet") (setq PaperSize "ISO_A3_(420.00_x_297.00_MM)")(vla-put-PlotRotation lay "0"))
                    (( = (vla-get-name blk) "A3P Drawing Sheet") (setq PaperSize "ISO_A3_(297.00_x_420.00_MM)")(vla-put-PlotRotation lay "1"))
                    (( = (vla-get-name blk) "A2 Drawing Sheet") (setq PaperSize "ISO_A2_(594.00_x_420.00_MM)")(vla-put-PlotRotation lay "0"))
                    (( = (vla-get-name blk) "A1 Drawing Sheet") (setq PaperSize "ISO_A1_(841.00_x_594.00_MM)")(vla-put-PlotRotation lay "0"))
                );cond
                );vlax-for blocks
                (princ (strcat "\nPaper Size for Model Space : " PaperSize))
            (vla-put-PlotRotation lay "1")            ;Drawing orientation 1=portrait 0=landscape
            (vla-put-stylesheet lay "acad.ctb")    ;set  the CTB
        );vlax-for
        nil t
);defun
  • 4 months later...
On 5/11/2022 at 5:38 AM, jr.roberto.santos said:
@Lee Mac
@BIGAL
Best regards,
(defun c:RV ( / )
    (LM:ODBX
        (function
            (lambda ( doc )
                (cond
                );cond
                );vlax-for blocks
        );vlax-for
        nil t
);defun
Hello there, I could not run this lispi. I got an error like this "; error: no function definition: LM:ODBX". Also, can we make a selection in the plot settings? scale, ctb.... THK YOU.
