Get latest drawing revision block with script
caddywampus
Hey all, this is my first post so I'm sorry if I violate any of the forum rules. I appreciate the help!
I'm trying to write a script to get the latest revision number from our drawings, then save that info into a text or CSV file. Each drawing has a revision block like the image tagged below. How would I do that in LISP?
Thanks!
Welcome to the forum my friend. Thank GOD that we have people like Lee Mac in the community. You do not need to re-invent the wheel because Lee has already done a neat job with this sort of task. Use Global Attribute Extractor & Editor lisp from Lee Mac (with this lisp you can ask to extract certain attribute from bunch of drawings - not necessarily all tags) and it will show the final results in CSV file afterwards.
Kudo to Lee Mac
This is an example of something similar shows how to change a ttribute value based on tag name but you can use GET rather than PUT and write out the value to a csv
; changes to issued for construction
: thanks to lee mac for original code
(vl-load-com)
; 1.  Get current date in mm/dd/yy format.
(defun ddmmyy (/ x today)
    (setvar "cmdecho" 0)
    (setq x (getvar "CDATE"))                 ; get current date
    (setq today ( rtos x 2 4))                    ; convert to a string
    (setq date (strcat (substr today 7 2) "."    (substr today 5 2) "." (substr today 3 2) ))
(setq oldtag1 "DRAWING_STATUS") ;attribute tag name
(setq newstr1 "ISSUED FOR CONSTRUCTION")
(setq oldtag2 "REV_NO")  ;attribute tag name
(setq newstr2 "0")
(setq ss1 (ssget "x"  '((0 . "INSERT") (2 . "DA1DRTXT"))))
(setq inc (sslength ss1))
(repeat inc
(foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (setq inc (1- inc)) )) 'getattributes)
(if (= oldtag1 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr1)
) ; end if
(if (= oldtag2 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr2)
) ; end if
) ; end for
) ;end repeat
(setq oldtag1 "REV-NO")
(setq newstr1 "0")
(ddmmyy)
(setq oldtag2 "DATE")
(setq newstr2 date)
(setq oldtag3 "AMENDMENT")
(setq newstr3 "ISSUED FOR CONSTRUCTION")
(setq ss2 (ssget "x"  '((0 . "INSERT") (2 . "REVTABLE"))))
(setq inc (sslength ss2))
(repeat inc
(foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss2 (setq inc (1- inc)))) 'getattributes)
(if (= oldtag3 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr3)
(setq ss1 nil)
; (setq ss2 nil)
Thanks bababarghi! I've downloaded and run the script. I can use the editor fine, but the extractor gives me an error when I use it on the block in my original screenshot named revision_text:
bad argument type: VLA-OBJECT nil
I noticed if I make up a random block name I don't get the error, it just returns nothing. Could something be amiss in that block?
Can you perhaps share your block with us?
Actually, I'm very close to what I need with the DATAEXTRACTION command. It outputs the contents of my revision_text block to a spreadsheet. I just need to add a filename or something so I can correlate each row to it's drawing file. Any idea how to do that?
