silviu Posted January 7, 2009 Share Posted January 7, 2009 hello, is there any possibility to set the 3d polylines so i can always see the vertices of every polyline in a draw? or a lisp that can do it? thank you Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted January 7, 2009 Share Posted January 7, 2009 Can you explain this more? Quote Link to comment Share on other sites More sharing options...
silviu Posted January 7, 2009 Author Share Posted January 7, 2009 you know how you see a selected polyline with the grip ( small square) around every vertex. i wonder if can set the display to always see that. i need that to see without selection, where the vertices are situated on polylines. there are some software with the possibility to "show vertices" ( especially gis software). i am working with autocad map 3d 2009. thank you. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 7, 2009 Share Posted January 7, 2009 Re: Grips. Consult your Help files. I doubt that you can display them continuously (i.e. - without making a slection). You might also try checking Tools > Options > Selection tab. Quote Link to comment Share on other sites More sharing options...
