Stevery
Blocks within a block, within a block ARGH
Stevery
Hi!
I have a floor plan that I would like to save as a xref file but before I do that I want to change the colour of everything on this dwg to 252.
I change all the layers to 252, and yet there are some parts which still show colour - the blocks!
The whole layout is in a block itself, so I go inside the block editor for that then there are blocks like doors inside which I can't edit because im already in the editor?
For now I have been bursting everything (some multiple times) just for me to be able to change the colours to by layer.
Is there a simpler way I can get around this without bursting all the blocks?
Share this post
Link to post
MillerMG
Before I got to the second to last line I was going to simply suggest burst. Could you possibly post the dwg?
Share this post
Link to post
danellis
Try the SETBYLAYER command.
dJE
Share this post
Link to post
Stevery
dJE
Exactly what I needed.
Thanks a lot! :)
Share this post
Link to post
danellis
Happy to have helped :)
dJE
Share this post
Link to post
Isham_Dean21
hats off to daniellis...i thought that this issue of mine was going to be so specific that i would've had a harder time finding my solution. perfect...thank you so much!
Share this post
Link to post
Chilidawg
I always make my block elements on layer "0" and set the colors and configurations per layer. I've had to go through other peoples drawings and change that, because I'm A-R that way.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
