bushlake
Changing line space factor for multiple Mtext
bushlake
Hello.
I want to change line space factor for all the mtext objects in a hole bunch of drawings by script.
I found this lisp and it works fine but only by manually selecting the mtext objects.
(setq vla_mtext (vlax-ename->vla-object (setq mymtext (car (entsel)))))
(vla-put-LineSpacingFactor vla_mtext 0.5)
Can this lisp be changed so it changes all mtext objects found in the drawing, or is there another way?
Thanks
Share this post
Link to post
Grrr
(defun C:test ( / acDoc scf cnt )
(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq scf 0.5)
(setq cnt 0)
(vlax-map-collection (vla-get-Block (vla-get-ActiveLayout acDoc))
	(function
		(lambda (x)
			(and
				(eq (vla-get-ObjectName x) "AcDbMText")
				(eq :vlax-false (vla-get-Lock (vla-item (vla-get-Layers acDoc) (vla-get-Layer x))))
				(vlax-property-available-p x 'LineSpacingFactor)
				(setq cnt (1+ cnt))
				(vla-put-LineSpacingFactor x scf)
(if (> cnt 0)
	(alert (strcat "\nProceeded " (itoa cnt) " mtext objects! "))
	(alert "\nNo mtext objects are found in this tab! ")
);| defun |; (or (vlax-get-acad-object) (vl-load-com)) (princ)
Or maybe just:
(defun C:test ( / scf SS i )
(princ "\nSelect mtexts to change their \"LineSpacingFactor\": ")
(setq scf 0.5)
(if (setq SS (ssget "_:L" (list (cons 0 "MTEXT"))))
	(repeat (setq i (sslength SS))
		(vla-put-LineSpacingFactor (vlax-ename->vla-object (ssname SS (setq i (1- i)))) scf)
(if SS (princ (strcat "\nProceeded " (itoa (sslength SS)) " mtext objects! ")))
Edited by Grrr
Share this post
Link to post
Lee Mac
Another:
(defun c:mtlsp ( / i s )
   (if (setq s (ssget "_X" '((0 . "MTEXT") (-4 . "<>") (44 . 0.5))))
       (repeat (setq i (sslength s))
           (entmod (append (entget (ssname s (setq i (1- i)))) '((44 . 0.5))))
Share this post
Link to post
BIGAL
I can see the next question oh I want a different spacing
(defun c:mtlsp ( / i s rnum)
   (setq rnum (getreal "\nEnter spacing <Cr> = 0.5 "))
   (if (= rnum nil)(setq rnum 0.5))
   (if (setq s (ssget "_X" (list (cons 0 "MTEXT") (cons -4  "<>") (cons 44 rnum))))
           (entmod (append (entget (ssname s (setq i (1- i)))) (list (cons 44 rnum))))
Share this post
Link to post
Grrr
BIGAL - the Prophet :D
Share this post
Link to post
bushlake
Another:
This code solved the problem perfectly, thanks again!!!
Share this post
Link to post
Lee Mac
You're most welcome :)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
