cooldraft
layout tab subfolders
cooldraft
I have huge amount of layouts in my DWG. I would like to have a possibility to organize them. Is there a way to modify AutoCAD to make the creation of layout sub-directories possible?
for example:
- Model
- Element 1:
-- Element 1 frame (Layout 1)
-- Element 1 sheeting (Layout 2)
- Element 2:
-- Element 2 frame (Layout 3)
-- Element 2 sheeting (Layout 4)
-- Element 3 details (Layout 5)
etc
Share this post
Link to post
RobDraw
Not without some programming.
If my layouts were getting out of hand, I would consider splitting up the file so that it is more manageable.
Share this post
Link to post
tombu
These links may help:
While pressing CTRL, press Page Up to cycle up (or left) or press Page Down to cycle down (or right) to cycle through the Layout and Model tabs.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cycling-through-Layout-tabs-using-keyboard-shortcuts.html
You can control how you change between the Model tab and one or more named layout tabs.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-LT/files/GUID-DE4888EE-F07D-40D7-94AB-0AD9A1741153-htm.html
I've also added a macro to toggle TILEMODE so I can toggle between the current layout and the Model tab.
Not exactly what you asked for, but workarounds many of us are using for your situation.
Share this post
Link to post
tzframpton
I'm with Rob on this one. Sheet Set Manager, or the old XREF Titleblock Sheet File is the way around this issue.
Share this post
Link to post
rkent
Sheet Set Manager would be the way to go for sure.
Share this post
Link to post
BIGAL
As a bit of a simple answer I take it you know you can move a layout tab so its at least in the correct order.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
