akim1220
Data Extraction and Blocks
akim1220
I currently have blocks with attributes for valves and within the blocks, it calls out a mounting plate and fitting. These blocks gets inserted into a design layout and once its completed, a data extraction is ran to create a bill of material pulling the part numbers from the blocks.
I would like to add different types of mounting hardware to the valve block so that the engineer can turn on the required layers and have that hardware data extract with the data extraction.
I tried this but even if the hardware layer is turned off, the data still gets extracted in the data extraction. Is there a way to do this?
Share this post
Link to post
BIGAL
You may have to write a custom data extraction using lisp etc to filter down the required output.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
