john-g
creating layer with code for each point
john-g
hello guys !!
im trying to import Points from Leica device and i want to creat a layer for each Point depending on its code ,if anyone have ideas how to do it i will be thanksfull
best regards !!!
Share this post
Link to post
eldon
That sounds very similar to stringing points.
For a fuller explanation, I would recommend that you do a web search using "survey stringing into cad".
Share this post
Link to post
BIGAL
Like eldon thats why programs like CIV3D exist.
I do have some knowledge about this being involved in civil software sales in the past.
I know it keeps coming back to me to do something.
The layer part is the easy part its the string that is hardest but I will try to explain a possible method. When you take a survey shot you record the object description eg "EB" or "403" edge of bitumen so that point goes on the layer "Ex_Edge_bit". You add a string prefix or suffix to the code which is a string that means join all 01EB together join all 02EB together in simple terms left and right. A possible solution is to use excel and sort twice sort the points based on ptnumber 1st then code second, noting 00EB is a point only. There is all sorts of smarts that can be added like a 3pt arc, a combo of two descriptions eg where a fence meets the intersection of another fence. I know these because it was in the software that I sold.
You can then line by line join and draw lines on correct layer. Its not rocket science just a involved task, that me for one just can not find the time to do it.
Can you post a Leica sample file I am not offering anything at this time but more about getting test data from different sources.
n,x,y,z,01EB
n,x,y,z,01EB
n,x,y,z,01EB
n,x,y,z,02EB
n,x,y,z,02EB
n,x,y,z,02EB
Share this post
Link to post
BIGAL
tombu you are correct I worked for Topcon and they wrote a dxf file that was strung.
Share this post
Link to post
tombu
Currently we use Trimble for data collection, but when I started at Leon County they did all their Cogo with Wildsoft which was a product of Leica until they quit supporting it in 1994. Did I just show my age?
Share this post
Link to post
