kapureef
Purge
kapureef
I have a dwg that only has two used layers. So I urged to minimize the size, yet I still have layers with nothing on them. I cannot get rid of them. Any suggestions?
Why are the layers remaining?
Any help would be greatly appreciated.
Thanx:(
Share this post
Link to post
BIGAL
The same thing happens in CIV3D and its tied to the Styles and the layers used by them, in CIV3d you can delete unused styles and purge layers. But it still leaves quite a few. The only way may be to wblock the dwg.
Share this post
Link to post
OMEGA-ThundeR
LAYDEL command, nuf said :)
Share this post
Link to post
kapureef
Thank you:D
Share this post
Link to post
MillerMG
Was going to suggest the same, Nice
Share this post
Link to post
tombu
As deleting Civil 3D layers referenced by styles could create havoc I would recommend creating a layer filter instead of deleting a layer being used by something in the drawing.
Share this post
Link to post
Cad64
Be careful with the LAYDEL command because it can and will delete layers that are currently being used in the drawing, so watch closely and make sure you're not deleting layers that you actually need.
Share this post
Link to post
MillerMG
VERY good point. Didn't think of that. Nice Cad64. As usual :notworthy:
Share this post
Link to post
OMEGA-ThundeR
Seeing that was the point it was the right command. But a little 'side effect' note can't harm :).
Share this post
Link to post
tombu
I have used LAYMRG for groups of layers I was sure I didn't need anymore, but LAYDEL should only be used if you know you want to get rid of all the objects, styles, etc… associated with that layer.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
