pkenewell Posted February 27 Share Posted February 27 (edited) @DELLA MAGGIORA YANN The Lisp and the DCL file should both be in one of the AutoCAD search paths. You can see what these are in the "Files" tab of the OPTIONS command; "Support File Search Path". You can also add your own folders into the search paths by selecting "Add" on the right side. Edited February 27 by pkenewell Quote Link to comment Share on other sites More sharing options...
DELLA MAGGIORA YANN Posted February 27 Share Posted February 27 J’ai bricscad 2024, je suppose que le principe est le même ? Quote Link to comment Share on other sites More sharing options...
DELLA MAGGIORA YANN Posted February 27 Share Posted February 27 ok I put the DCL in SUPPORT and it works now, however I don't know how to put the correct units I would like to have a drawing in millimeters, a material thickness in millimeters and a result in kilograms and then I have a display problem, in fact the result is only partially displayed, can you help me please I am very bad at LISP language Quote Link to comment Share on other sites More sharing options...
pkenewell Posted February 27 Share Posted February 27 54 minutes ago, DELLA MAGGIORA YANN said: J’ai bricscad 2024, je suppose que le principe est le même ? Yes I believe so, but I don't have BricsCAD so I don't know for certain. Quote Link to comment Share on other sites More sharing options...
pkenewell Posted February 27 Share Posted February 27 (edited) 23 hours ago, DELLA MAGGIORA YANN said: I don't know how to put the correct units I would like to have a drawing in millimeters, a material thickness in millimeters and a result in kilograms and then I have a display problem, in fact the result is only partially displayed, can you help me please I am very bad at LISP language @DELLA MAGGIORA YANN I made an updated version of Jeffrey's original to allow changing the weight units to different values - give the attached a try. EDIT: Updated DCL to use edit boxes for the results, which may display better in some systems. WEIGHT.lsp WEIGHT.dcl Edited February 28 by pkenewell Added clarification, Update Code, Corrected errors. Quote Link to comment Share on other sites More sharing options...
pkenewell Posted February 27 Share Posted February 27 (edited) EDIT: Updated my above Alteration to also use Region boundaries and subtracting islands (for example: holes in the plate) for a better way to get areas than just getting single polyline boundaries. I also added a couple more materials. I will probably go back later and localize everything, as Jeffrey's original program has NO localized variables. Edited February 27 by pkenewell 1 Quote Link to comment Share on other sites More sharing options...
pkenewell Posted February 27 Share Posted February 27 29 minutes ago, pkenewell said: I will probably go back later and localize everything, as Jeffrey's original program has NO localized variables. Edited Above Again and localized all the variables. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 27 Share Posted February 27 99% of code works with Briscad. A few things but you find them, as new versions come out some of the problems go away. Something I use is the convert dcl to lisp by RLX then you have only 1 file, as the dcl lives in the lsp. Convert dcl 2 lisp rlx.lsp 1 Quote Link to comment Share on other sites More sharing options...
DELLA MAGGIORA YANN Posted February 28 Share Posted February 28 Il y a 9 heures, pkenewell a dit : Édité à nouveau ci-dessus et localisé toutes les variables. Great work, you impress me!!! this seems to work. However, I have a display problem in the dialog box. In fact the results are not visible, I will provide you with a screenshot. I have another question to make sure I understand correctly. -1- I therefore choose milimeters because my model is in milimeters, -2- I choose my material, “glass” -3- I choose the weight unit “kg” -4- I select or manually enter the surface in millimeters “mm²” and this should give me the result of the volume and the weight? and as I told you I can't see the results because of the display problem. I would like to thank you for your work. Quote Link to comment Share on other sites More sharing options...
DELLA MAGGIORA YANN Posted February 28 Share Posted February 28 6 hours ago, BIGAL said: 99% du code fonctionne avec Briscad. Quelques choses, mais vous les trouvez, au fur et à mesure que de nouvelles versions sortent, certains des problèmes disparaissent. Quelque chose que j’utilise est la conversion de dcl en lisp par RLX, alors vous n’avez qu’un seul fichier, car le dcl vit dans le lsp. Convertir dcl 2 lisp rlx.lsp 4.38 kB · 0 téléchargements I thank you for your interest in me, However I don't understand how it works can you tell me wei Quote Link to comment Share on other sites More sharing options...
pkenewell Posted February 28 Share Posted February 28 8 hours ago, DELLA MAGGIORA YANN said: this should give me the result of the volume and the weight? and as I told you I can't see the results because of the display problem Very Strange. It works fine in my AutoCAD. It may have something to do with your display settings. I will play around with the DCL file and see if I can get it to do something different. Quote Link to comment Share on other sites More sharing options...
pkenewell Posted February 28 Share Posted February 28 (edited) @DELLA MAGGIORA YANN OK. I made an update to the DCL in my Post above. Please re-download it and give it a try. I changed the DCL to use edit boxes for the results instead of just text labels. hopefully this will work better in your setup. Example: Edited February 28 by pkenewell Quote Link to comment Share on other sites More sharing options...
DELLA MAGGIORA YANN Posted February 28 Share Posted February 28 (edited) OK SUPER NICE I'LL TEST THIS IN A MOMENT AGAIN THANK YOU IT'S GREAT Edited February 28 by DELLA MAGGIORA YANN Quote Link to comment Share on other sites More sharing options...
DELLA MAGGIORA YANN Posted February 28 Share Posted February 28 It's good, it works, it's great, a big thank you just a small question if possible otherwise it doesn't matter, it can stay like that. Do you think it is possible to put the density in kg/m3? as on screenshot keeping the units in millimeter if it's not too complicated of course. another thousand thanks you are great Quote Link to comment Share on other sites More sharing options...
pkenewell Posted February 28 Share Posted February 28 (edited) @DELLA MAGGIORA YANN Great! I am glad it's working for you. Note - the program is completely dependant on the selected units. If you want it to show in kg/m3, just temporarily change the units at the top to "Meters" and it will update the density in real-time, then you can change it back to "millimeters" for the correct object weight to be displayed. I like this program and I may revisit the program at sometime in the near future and re-write it for more features, but for now this will have to do for you. Edited February 28 by pkenewell 1 Quote Link to comment Share on other sites More sharing options...
DELLA MAGGIORA YANN Posted February 28 Share Posted February 28 thanks you verry mutch: Quote Link to comment Share on other sites More sharing options...
