Help - Select lines and overlaping in the same coordinate
teknomatika
In the attached file, two lines are represented, apparently overlapping. In fact there is one out of the way between 0.0001.
Someone will be able to achieve a routine that makes it possible to select the lines, overlapping them with the same y-coordinate. Of course, also for distant lines with other values.
This is an example for horizontal lines but needed equally for vertical lines.
Thanks!
test_lines.dwg
Not likely to be quick, but should work:
(defun c:linedupes ( / a f i l r s x )
   (setq f 1e-3) ;; Fuzz
   (if (setq s (ssget "_X" (list '(0 . "LINE") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
           (repeat (setq i (sslength s))
               (setq x (entget (ssname s (setq i (1- i))))
                     l (cons (list (cdr (assoc 10 x)) (cdr (assoc 11 x)) (cdr (assoc -1 x))) l)
           (setq r (ssadd))
           (while (setq a (car l))
               (foreach b (setq l (cdr l))
                   (if (or (and (equal (car  a) (car  b) f)
                                (equal (cadr a) (cadr b) f)
                           (and (equal (cadr a) (car  b) f)
                                (equal (car  a) (cadr b) f)
                       (progn (ssadd (last a) r) (ssadd (last b) r))
           (if (< 0 (setq n (sslength r)))
                   (princ (strcat "\n" (itoa n) " duplicate line" (if (= 1 n) "" "s") " found."))
                   (sssetfirst nil r)
               (princ "\nNo duplicate lines found.")
Lee,
Thanks for the attention. Always with fantastic solutions.
It works on the part of the selection. Furthermore, in a second step, I intend that once detected, the lines will be moved to overlap each other.
In summary, I want to detect the offset difference between the lines, overlap them and maintain, even if duplicated.
Thanks!
Assuming I've understood correctly, try the following:
(defun c:linedupes ( / a b f i l m p r s x )
                     l (cons (list (cdr (assoc 10 x)) (cdr (assoc 11 x)) (assoc -1 x)) l)
                   (cond
                       (   (and (equal (car  a) (car  b) f)
                           (setq m (cons b m))
                       (   (and (equal (cadr a) (car  b) f)
                           (setq m (cons (list (cadr b) (car b) (last b)) m))
               (if m (setq r (cons (cons a m) r) m nil))
           (foreach x r
               (setq p
                   (mapcar
                      '(lambda ( a b ) (cons a (avgpt b)))
                      '(10 11)
                       (list (mapcar 'car x) (mapcar 'cadr x))
               (foreach y x (entmod (cons (last y) p)))
(defun avgpt ( l )
   (mapcar '(lambda ( x ) (/ x (length l))) (apply 'mapcar (cons '+ l)))
Lee,
You really are the best. Thanks!
That's exactly it. To be even perfect for what I intend, I should also consider lines of different lengths. But it will already be wanting a lot.:)
