keiths
Lisp routine to create chevron markings
keiths
Hi,
Where can i find a lisp routine to create chevrons as used on gores or median islands.
Share this post
Link to post
ReMark
I think CadTools has a chevron feature.
Share this post
Link to post
BIGAL
Have a play with this not really finished but.
; chevron island creater
; this use the extrim command to trim shape
; By Alan H Jan 2012
(defun C:Chevron ( / obj pt1 pt2 pt3 pt4 newpt1 newpt2 )
(acet-error-init (list
                  (list   "cmdecho" 0
                        "highlight" 0
                        "regenmode" 1
                           "osmode" 0
                          "ucsicon" 0
                       "offsetdist" 0
                           "attreq" 0
                         "plinewid" 0
                        "plinetype" 1
                         "gridmode" 0
                          "celtype" "CONTINUOUS"
                        "ucsfollow" 0
                         "limcheck" 0
                  T     ;flag. True means use undo for error clean up.
                  '(if redraw_it (redraw na 4))
                 );list
);acet-error-init
(setq obj (car (entsel "\nPick pline or circle")))
; should do a object test here
(setq whatis (cdr (assoc 0 (entget obj))))
(if (= whatis "LWPOLYLINE")
(princ "\You have picked something other than a polyline ")
(princ "\Remake into a pline and do again ")
(setq dummy (getstring "\press any key"))
(exit)
) ; progn
) ; if
(setq pt1 (Getpoint "\nPick Line start point"))
(setq pt2 (Getpoint pt1 "\nPick end point"))
(command "line" pt1 pt2 "")
(setq gap1 (getreal "\nenter spacing 1"))
(setq gap2 (getreal "\nenter spacing 2"))
(setq pt3 (getpoint "\nPick 1st cross point"))
(setq pt4 (getpoint pt3 "\nPick 2nd cross point"))
(setq dist (distance pt3 pt4))
(setq x (fix (/ dist (+ gap1 gap2))))
(setq newpt1 (strcat (rtos gap1 2 2) ",0.0"))
(setq newpt2 (strcat (rtos gap2 2 2) ",0.0"))
(repeat x
(command "copy" "L" "" "0,0" newpt1)
(command "copy" "L" "" "0,0" newpt2)
(load "Extrim")
(etrim obj pt1)
(acet-error-restore)
) ; end defun
Share this post
Link to post
BIGAL
Readable version below, Maunsell is a very large engineering company obviously in Adelaide Australia. Not sure if it was to be released to the public.
; removed as I dont want to be sued by Maunsell's
Share this post
Link to post
yathishkumar
Thank you for your reply and changed to Readable version bigal sir.
But actually​ I don't about Maunsell now I understood.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
