thanhdattdk
Code Lisp entget Hatch
thanhdattdk
Hello everbody. Thank all for read my thread
I want to determine the blue dot coordinates but fail. i hope everybody help me code lisp
My code
;;------------------------------=={  2017  }==-------------------------------;;
(prompt "\n=={Created by PHÒNG TKCD - CIENCO625******************************}==")
(prompt "\n=={Thanhdattdk@gmail.com******************************}==")
(defun c:mm ()
(princ "\nCh\U+1ECDn c\U+00E1c Hatch c\U+1EA7n t\U+1EA1o l\U+1EA1i Boundary : ")
(command "-style" "DIENTICH" "arialbd_0.ttf" "0" "0.9" "0" "n" "n")
(setq tnct (ssget (list (cons 0 "HATCH"))))
(setq i 0)
(setq lmt (sslength tnct))
(while (< i lmt)
		(setq e (ssname tnct i))
		(setq laynd (entget e))
		[b][color="blue"](setq td (cdr (assoc 10 laynd)))[/color][/b]
	;tao tap rong de tinh dien tinh cho Hatch tao nhieu PL
	(setq S 0)
	(setq Q (entlast) AA (ssadd))
	(command "-hatchedit" e "B" "P" "")
	(while
	(setq Q (entnext Q))
	(setq AA (ssadd Q AA))
;tinh dien tich cac phan tu cua group vua tao
(setq j 0)
(setq dat (sslength AA))
(while (< j dat)
(setq doituong (ssname AA j))
(command "area" "o" doituong)
(setq Si (getvar "area"))
(setq S (+ S Si))
(setq j (+ j 1))
(princ S)
(princ td)
(command ".ERASE" AA "")
;viet text len vi tri hatch
(command "text" "ml" td "2.5" "0" S "")
(setq i (+ i 1))
);END WHILE
(princ))
Share this post
Link to post
BIGAL
A quicker way maybe is use BPOLY it makes a pline of your hatch boundary, you can then get simply the co-ordinates of the new pline and theer are some centroid routines out there as well.
Share this post
Link to post
Roy_043
Since you are using the point to position text, why not calculate the center of the boundingbox instead of the centroid?
Share this post
Link to post
thanhdattdk
thank you very much.
(setq Rec (acet-ent-geomextents e)
pt1 (nth 0 Rec);lay dinh
pt2 (nth 1 Rec);lay dinh
mid (acet-geom-midpoint pt1 pt2)
);setq
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
