Using Windows Search for Information Inside Drawings
07lodgeT
 Share
Hello,
Is there a way of searching across a number of AutoCAD files for files containing particular text? This used to be possible in Windows XP, but does now not work in Windows 7 annoyingly. We have thousands of DWG files that have been drawn up over the past 20 years and to be able to search for a particular text string in a file would be hugely beneficial, such as part numbers and job numbers etc.
We are running Windows 7 and AutoCAD 2018 LT.
Can this be done with our current setup, or is there a another program we could use? I believe Autodesk Content Explorer used to serve this function, but has now been discontinued.
Your help would be greatly appreciated.
Welcome to CADTutor 07lodgeT. :)
When in doubt, check Lee Mac out.
http://www.lee-mac.com/bfind.html
Thanks Lee! :beer:
Better yet, before you are in doubt, check out his incredible offerings preemptively.
Whoops, you are using LT, no lisp!
Do you have access to a non LT machine on which you could use this?
Edited by Dadgad
Thanks Lee! :beer:
Thanks for that, unfortunately Autocad LT doesn't support LISP or VB
"FINDSTR" is for text files it is a Windows command line operating system option. There may be a binary version. Else you will need a compiled .net version of something like bfind.
Findstr VLA *.lsp
 Share
