amir0914
Draw Polyline by list of coordinate
amir0914
Hello everybody,,
how can i draw polyline by list of x,y coordinate ?? :
list = ((x1 y1)(x2 y2)(x3 y3)(x4 y4) ......)
example my coordinate :
((2420.96 1612.3) (2422.96 1612.25) (2423.96 1612.12) (2424.96 1612.24) (2425.96 1612.09) (2426.96 1612.14) (2427.96 1612.08) (2429.84 1612.08) (2430.06 1612.15) (2430.96 1612.12) (2431.96 1612.17) (2432.46 1612.17))
Thanks in advance,
Share this post
Link to post
ronjonp
You can use the function HERE to do this.
Share this post
Link to post
benhubel
Apparently I'm just a couple minutes too late. Still, I'll post what I wrote anyway. It's really simple and there may be bugs, but it seems to work with your data-set, at least.
(defun c:writepoints ( / verts index)
(setq verts '((2420.96 1612.3)(2422.96 1612.25)(2423.96 1612.12)(2424.96 1612.24)(2425.96 1612.09)(2426.96 1612.14)(2427.96 1612.08)(2429.84 1612.08)(2430.06 1612.15)(2430.96 1612.12)(2431.96 1612.17)(2432.46 1612.17)))
(setq index 0)
(repeat (1- (length verts))
	(command "_.line" (append (nth index verts) '(0.0)) (append (nth (1+ index) verts) '(0.0)) "")
	(setq index (1+ index))
Share this post
Link to post
Grrr
(defun C:test ( / PointList )
 (setq PointList
     (2425.96 1612.09) (2426.96 1612.14) (2427.96 1612.0) (2429.84 1612.0)
 (LWPoly PointList
   (if (progn (initget "Yes No") (member (getkword "\nClosed ? [Yes/No] <Yes>: ") '(nil "Yes"))) 1 0)
); defun
(defun LWPoly (lst cls) ; LM's entmake functions
 (entmakex
   (append
     (list
       (cons 0 "LWPOLYLINE")
       (cons 100 "AcDbEntity")
       (cons 100 "AcDbPolyline")
       (cons 90 (length lst))
       (cons 70 cls)
     (mapcar (function (lambda (p) (cons 10 p))) lst)
Share this post
Link to post
amir0914
(setq index 0)
Thanks benhubel, your code is work and it dont have any bugs. thanks alot for your help :)
Share this post
Link to post
amir0914
 (setq PointList
 (LWPoly PointList
); defun
 (entmakex
   (append
     (list
       (cons 70 cls)
Grrr, Thank you for your time, your code that's what I want, thanks alot.
Share this post
Link to post
BIGAL
Another way
; create pline from a list
; by Alan H
(command "_pline")
(while (= (getvar "cmdactive") 1 )
(repeat (setq x (length lst))
(command (nth (setq x (- x 1)) lst))
(command "")
Share this post
Link to post
eldon
Writing a lisp to draw one polyline seems an awful lot of effort with maximum chance of mistakes whilst typing all those digits.
If your data is in the form of a csv file of coordinates, there are simpler ways of drawing a polyline.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
