Bobzy20
Remove all 3DSolids within Blocks Script
Bobzy20
Hi
Does anybody know of a script for AutoCAD 2012 that will remove all 3DSolids within a drawing even if they are nested within a block/s?
Any help would be great
Thanks
Bob
Share this post
Link to post
Roy_043
This can't be done with a script (*.scr). But a Lisp solution is possible:
(defun c:Test ( / doc)
 (setq doc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-endundomark doc)
 (vla-startundomark doc)
 (vlax-for blk (vla-get-blocks doc)
   (vlax-for obj blk
     (if (= "AcDb3dSolid" (vla-get-objectname obj))
       (vla-delete obj)
Share this post
Link to post
BIGAL
Add this before the (princ) to remove other solids
(setq ss (ssget "X" (list (cons 0 "3dSolid"))))
(command "erase" ss "")
Share this post
Link to post
Bobzy20
Thank you both for your help.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
