2D elevation setting
zionshea
When generating a 2D elevation or Section it generates a block where all lines are with same color and width and type.
1. Is it possible to control these lines according to the element (e.g. a certain line for doors and another for windows and walls and so on).
2. Is it possible to control the amount of included lines based on the distance between lines - in many cases I see many adjacent lines, this is the case especially with rails.
Thanks a lot.
Autocad Architecture
Actually I've updated the 2d Elevation Style and changed some subdivisions - I managed to change the 2D elevation output but it was not what I expected (it changed all the elevation - I could not change a certain object within the elevation output).
