BIGAL Posted August 26, 2017 Posted August 26, 2017 Once exploded there just objects you could look for patterns of objects but thats a huge task. Quote
SLW210 Posted August 28, 2017 Posted August 28, 2017 Is the block reference still in the drawing? Quote
MTTLP Posted August 28, 2017 Author Posted August 28, 2017 Is the block reference still in the drawing? Blocks deleted There is only drawing Quote
ReMark Posted August 28, 2017 Posted August 28, 2017 Who created the drawing? Do you remember any of the block names? Were the block definitions purged? Quote
MTTLP Posted August 28, 2017 Author Posted August 28, 2017 Drawing21.dwg[/ATTACH] MTTLPAttach a sample file .dwg How to find the exploded blocks Quote
maratovich Posted August 28, 2017 Posted August 28, 2017 Most likely not, but if it is possible, it will be very expensive. Quote
BIGAL Posted August 29, 2017 Posted August 29, 2017 No automation only simplify manual change, pick objects make block with a insert point, a lisp macro etc pick point, window object and erase, insert correct block. Trying to find patterns would be hard, washing machine outside pline check area then erase and insert, toilet length of one line and so on. By the time even start coding maybe all done. Quote
steven-g Posted August 29, 2017 Posted August 29, 2017 Unfortunately there is no help in the drawing, other than recreating it all as BIGAL says, do you not have access to an old version from before that it was all exploded, maybe a previous revision, archive, old e-mail with a sent copy, backup file. Other than that your only option is start again. Quote
