jetxcc
change visibility states using a field
jetxcc
Hello all,
I have posted as a reply on other post to try and find a way to make what seems to be impossible...possible...First and foremost...I KNOW THE EXACT EQUIVALENT OF SQUAT!! about writing, reading, or understanding LISP or the verbiage associated with it. That being said, I would like to know in the most simplistic of terms, how to change the visibility state of a dynamic block using a field that is referenced from an Excel sheet. Here are the steps that I would like to take in order for what I want to accomplish to happen:
open excel file
input visibility state data for the block in a designated cell
save the excel file
open the AutoCAD dwg
print (and have the block associated with the Excel input displaying the correct visibility state)
I have attached a very simple block and excel sheet with this message, in the excel sheet I have copied the block information from the various visibility states using the LIST command in AutoCAD. I am currently using AutoCAD Mechanical 2018, but this block was made in AutoCAD Mechanical 2016.
Here is a code that I copied from a very knowledgeable resource on LISP routines, Mr. Lee Mac, which I am sure that most of you have heard of.
;; Set Dynamic Block Visibility State - Lee Mac
;; Sets the Visibility Parameter of a Dynamic Block (if present) to a specific value (if allowed)
;; blk - [vla] VLA Dynamic Block Reference object
;; val - [str] Visibility State Parameter value
;; Returns: [str] New value of Visibility Parameter, else nil
(defun LM:SetVisibilityState ( blk val / vis )
(if
(and
(setq vis (LM:getvisibilityparametername blk))
(member (strcase val) (mapcar 'strcase (LM:getdynpropallowedvalues blk vis)))
(LM:setdynpropvalue blk vis val)
My problem is the utterly embarrassing lack of knowledge when it comes to LISP code, so I have absolutely NO idea as to how to utilize or implement his program, what variables to change to fit my drawing or how to make it reference the field or Excel sheet. So any help would be greatly appreciated, and please, feel free to assume that you are talking to a complete idiot on the subject of LISP, because you are, and feel free to explain even OVER explain in detail the changes that I need to make in order to make this little bit of happiness work for me. Thank you in advance for all of those that have taken the time to read this, and have input to share.
Thank you,
Jetxcc
Share this post
Link to post
