jeff james
extrude problem
jeff james
I am a newbie, Am using Acad 2013. I did not know how to title question enough to search if it has been answered before. I have been doing exercises on Mr.Z youtube channel, everything was just fine. The cube project started and if I drew a square and tried to extrude it by same unit as x-y it always now ends up as a very short 3d box instead of all 3 axes equal. I have created gears and completed a 3d house with no trouble. what setting did I mess up?
Share this post
Link to post
BIGAL
How are you entering the height ?
Share this post
Link to post
jeff james
i draw equal square with rectangle command typing any same unit. If units set to mm i enter 10 units for example for one dimension then tab and 10 for the next, enter, I get a perfect square, then I use tilt drawing a little and use extrude command, pick my square and drag it upward.... it follows upward ad usual waiting for you to pick a height, so I type 10 units in and hit enter.
I get a very short cube. it is as if Z axis units are less than X and Y.
Share this post
Link to post
BIGAL
Works for me do you have Snap on this may cause a problem. You don't need to be in a 3d view as you do extrude just feel confident and enter height when prompted then check -vpoint 1,1,1 You can use -10 to go down rather than up.
Share this post
Link to post
jeff james
Still a problem, this is simple operation i have done dozens of times. I should be able to start a new drawing and draw a square and extrude it to a cube. the unit does not seem to be the same on z as it is in x and y. I can enter 1 or 10 or 100 units on each parameter and I currently get a square box that is very short.
Share this post
Link to post
BIGAL
Re check snap option Aspect has two options Hor and vert they can be different.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
