mflorindi
enhanced attribute editor dialog box size
Just stretch using the edges of the Dialog Box.
Are you wanting the resizing to remain?
Do you have more than one monitor?
For some reason, if you move the Dialog Box to the other screen, pulling the edges of the Dialog Box remains.
Share this post
Link to post
Hi, Forgot to be more specific at Autodesk too. Sorry.
I'm looking for the default dialog box size to be larger. Sure I can scroll or drag. But its a hassle. I have room for the default box to be 4 times the size. Right now I can only see 3.5 tags of 15 in the box. All my changes are on the 10th tag and their not typical. So I can't script. Also the routines are now arx's. So I can't modify them. Need someone to see if the older versions of cad have the attedit command in .lsp. If the size could be modified there, I could just load that routine with cad and use it instead of -eattedit (by double click on the att block.) These are controls electrical schematic titleblocks. Wish I had more time to throw at this. Thanks!
Share this post
Link to post
Did you even read my response or try what information I provided?
If you only use one monitor, the size should remain after stretching it AFAIK.
What more are you wanting?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
