fields as attributes/sheet set title block/dont plot empty fields?
hi all
i have a title block with all the components (attributes) set as fields.
i would like to set the fields as attributes to the title block 'block' so it can be used as the template to start a drawing in my sheet set.
i have thus far:
1. the titleblock is a block in a dwg.
2. the dwg is (temporarily) a sheet in the sheet set i need it for (so i can give it sheet custom fields).
3. all the attributes for the titleblock are fields.
now im stuck.
what i would like to do is:
1. create a block comprising all these fields (the title block attributes) so they are in a new dwg when i add it as a sheet to the sheet set.
2. have it be able to be updated as per a regular title block so i can arrange their order, ie; define the fields as attributes in order.
3. have empty fields not print out with "----" when they are empty!!
i hope this is clear.
thanks very much for any help. :)
